Kodi does not have any license unfortunately.
[ROM] Beelink GTKing SC v1.0 ( W.I.P. AndroidTV 9.0 )
superceleron
I use Your rom but i have an issue which is not only with your rom. I have a Samsung soundbar Hw-q90R and a Samsung TV QE55Q6FNA 4k UHD.
When i connect the GT-king dirrect to TV HDMI is O.K. When i connect the box to Soundbar HDMI in and the HDMI(ARC) to TV (for the Dolby Atmos) the video signal is lost, have to connect disconnect randomly cables for getting back the signal. First i thought its a Soundbar issue. But if i try anodher 4K device example xbox one s the HDMI issues non exist. After that i accepted this is a incompatibily between soundbar and king. But i install Coreelec to the king and voila hdmi issue isn't exist. So it have to be firmware issue mainly in the stock firmware too. Sorry if it was to long, but it made me crazy from 2-3 days. Could ou imagine what the trouble is? Thank You again for the firmware
Originally posted by theholyguy View Post
Would like to use the normal version for B922, why not public?
Well wait for the newer build im making, maybe that is fixed and i used a newer android 9 aml sdk and lots is fixed in that one!
Because i still dint finished, this build are done from source and it will take lot more time than use a already prebuilt(stock fw) fw like must do + i do my own fixes in the source!
I made Beelink GT-King firmware and the console was blocked. Only a welcome screen saver. Reset does not work. The prefix was not in operation. Just such a surprise. What to do Did the firmware via the USB Burning Tool. Did twice, both options. After the second firmware, only the splash screen has changed.
There are currently 1290 users online. 0 members and 1290 guests.
