But as soon as i test it i will check that out!
[ROM] Beelink GTKing SC v1.0 ( W.I.P. AndroidTV 9.0 )
superceleron i got my box B922 version yesterday and Ethernet is working fine on my box, only for your Information.
superceleron,there are many people reporting that is an ethernet problem with this boxs. Good for the ones that don?t have problems, but for the one having a faulty box are in the Hands of the Devs that make Custom Firmwares to try to fix thing up, because we can?t hope for Beelink support.
The problems are reported in:
and
so they are not an isolated case.
Originally posted by superceleron View Posthmm i will check mine, if it is ok then can only be a hw issue in a batch of boxes!
Because me and some of my friends are very happy with this box (SN B922), because Ethernet is working very well without any issuesLast edited by tombraga; 08-09-2019, 14:18.
Originally posted by tombraga View Post
Now i am also very curious, if you can connect Ethernet or not superceleron
Yes(just opened the B version just now after 3 weeks lol... ye been busy) since i have both versions of this box.
So only beelink can know what batch had the issue, i think!
I have a B922 - I found it is sometime tempremental to connect to the internet with the ethernet cable . First time no connection at all on ethernet - I tried connecting with wifi only then plugging in the ethernet cable then reboot and switch off wifi. .Current loaded with alvatech ROM. At the moment checking Internet settings it is stating with WIFI switch off and scanning always available ON that the ethernet is not connected but showing the IP address of my HDMI matrix to which it is connected and running great on my fiber lines. Strange buts working somehow
Originally posted by sesdave View PostI have a B922 - I found it is sometime tempremental to connect to the internet with the ethernet cable . First time no connection at all on ethernet - I tried connecting with wifi only then plugging in the ethernet cable then reboot and switch off wifi. .Current loaded with alvatech ROM. At the moment checking Internet settings it is stating with WIFI switch off and scanning always available ON that the ethernet is not connected but showing the IP address of my HDMI matrix to which it is connected and running great on my fiber lines. Strange buts working somehow
There are currently 2472 users online. 6 members and 2466 guests.
