This is a nice clean ROM with some tweaks, GUI cleanup, Mods and some changes made from the original GT-King ROM.
Please read the entire first post before asking questions. Thank you.
(There has been some hardware variants so please read carefully.)
Best thing to do before flashing your box is to check which Serial Number you currently have on the bottom of your box.
I've made 3 different ROM's for the following boxes starting with SN: 922X &SN:95X2 another for SN:B922 and SN:C92X & SA9X.
Please download the correct ROM for your box down below.
Changes/Mods & Tweaks Alvatech ROM:
- This ROM is based off of Beelink's Firmware.
- Removed unneeded apps that Beelink had installed.
- Cleaned up Beelink's scripts that I don't use in this ROM.
- Nicer mouse cursor for easy viewing.
- Top status bar now working.
- Double click home button brings up Recent Apps in Grid View.
- Long Press on home button brings up Google Assistant.
- Clock setup in 12hr / 24hr format.
- Two Launchers: Square Home 3 , Android One Launcher.
- Added TV Settings in app drawer.
- Additional Apps: X-Plore File Manager, Smart YouTube TV, Netflix, Kodi, & Power Menu (With Recovery Boot Option)
- Added additional *kl files to support more devices.
- Removed and cleaned up files that are no longer needed.
- Added 4K support for different YouTube versions.
- Updated Generic.kl to use the "Enter" Key.
- Fixed a permission grant issue
- Added Google Clock (screen saver too).
- Change screen saver options in TV Settings / Device Preferences
- Updated GApps
- Alvatech Boot Logo and Boot Animation
- New Wallpaper
- TWRP Recovery now added.
- Other system tweaks and changes, I'll update more info as I remember.
- Used latest version of Beelink's ROM's as a base to build these.
- Added New ROM for SN:B922 Boxes
- Updated Apps: X-Plore File Manger, Smart YouTube TV, & Kodi
- Updated GApps.
- Added TWRP Recovery.
- Netlfix Audio now works without messing with slider back and forth.
- Other small changes.
- Made 2 different ROM's for the different serial numbers.
- Added Extra options in TV Settings (side settings).
- Added Multi Webview options under Developer options / WebView Implementation.
- Updated Apps: Square Home 3, X-Plore File Manger, Smart YouTube TV, & Kodi
- Updated GApps & Permissions.
- Added Backdrop from Android TV for screen saver. You can change when to initiate it in TV Settings.
- Added Setup Wizard so users can choose language during first time initialization.
- Added Android TV remote control.
- Fixed some framework issues.
- HDMI CEC Language turned off by default.
- Other small changes, will add as I remember.
- All changes from above still apply
- 12 Hour Static Fixed.
- Top status bar is now working.
- Updated Apps: Square Home 3, X-Plore File Manger, & Smart YouTube TV
- IPTV Fix
- Miracast for Android Phones
- System Optimizations
- All changes from above still apply.
- Fixed an issue with voice typing throughout Android OS.
- Updated Apps: Kodi 18.5, X-Plore File Manger, & Smart YouTube TV
- Made 3 different ROM's for the different serial numbers.
- All changes from above still apply unless specified.
- Long Press power button on remote for System Switch option.
- Fixed voice support for other remotes too. Example G30S remote.
- Removed Chromecast banner from backdrop screensaver.
- Removed Long Press Google Assistant. If needed use win key on a keyboard.
- Updated Apps: Kodi, X-Plore File Manger, & Smart YouTube TV
Changes 11/30/20:
- Updated Apps: Kodi, Square Home3, X-Plore File Manger, & Smart YouTube TV
- Smart Youtube or Screensaver issues? (if so, please see 2nd post Tip #4, Tip #5).
- New Alvatech boot logo
- New wallpaper
- Other changes, will update as I remember.
Donation:
A token of appreciation is always welcomed. Thank you!
Donation Link Here
Notes:
Please read the "Extra Tips Section" on the 2nd post for additional help.
When the box boots for the first time only, installation is still going on in the background please be patient for it to load completely.
When you connect the box to the internet for the first time google dependencies will need to be updated, please allow for these updates to finish.
Download ROM for SN:922X or SN:95X2:
GT_King_AT_V6.0_922X
Download ROM for SN:B922:
GT_King_AT_V6.0_B922
Download ROM for SN:C92X SN:SA9X, or SN:SB9X:
GT_King_AT_V6.0_C92X
Installation Instructions:
Recommend Using Latest Amlogic's USB Burning Tool 2.1.7.0 or later. SD Card Method can be used.
First, open the USB Burning Tool, then in the top left corner click File / Import image and click on the downloaded ROM image file. When you finish loading the ROM press the Start button on the right hand side of the USB Burning Tool. Next plug in one end of the USB cable to your PC. USB 3.0 ports on a PC seem to work better than the USB 2.0 ports, but USB 2.0 ports work too. Next plug in the power cable into your box, and as soon as you see the eyes turn green on the box, you need to immediately plug in the other end of the USB cable into the USB 2.0 port of your box (the one next to the power jack). Do not use any other USB ports as they will not work. Be persistent until you succeed if you fail at first.
Very Important! when you flash your box either by USB or SD-Card NEVER use the option Force Erase All only use the Normal Erase option or you will lose DRM Widevine L1.
Click the needed link down below to download the tool needed.
USB Burning Tool Method: Amlogic's USB Burning Tool
SD Card Method: Amlogic's Burn Card Maker
1ST BOOT TAKES ABOUT 5-6 MINUTES, SO PLEASE BE PATIENT.
THIS DELETES ALL YOUR DATA SO DO A BACKUP IF NEEDED! USE THIS AT YOUR OWN RISK!
This is to share my work with everyone and to try to make these TV boxes more enjoyable.
I will try my best to answer or help with any questions and or concerns as soon as I can.
If something doesn't function properly please let me know with as much detail as possible and I will try to fix it.
When posting for help please stay on subject, If it doesn't pertain to this ROM please search other threads for help or start a new thread.
I HOPE YOU ENJOY IT AS MUCH AS I DO!!
Thank you Beelink for the sample hardware.
You can get the Beelink GT King >> here << and help support Freaktab.
