[ROM] Beelink GT-King ALVATECH Standard Android (9.0 Pie) S922X
Originally posted by tomyrambozha View Post
i have flash with usb burning tool to my gt king SN B922, and after restart , my device was result as a Blank screen , is that normally ? or ?
Thank you,
Alvatech
Originally posted by ALVATECH View Post
Not sure why this is happening. I would retry flashing your box. I?ve had other users flash this ROM on their box without any issues. You can try to flash with USB tool again or you can try the SDCard method if it continues to fail. I feel something didn?t flash right the first time. I would try again.
Thank you,
AlvatechLast edited by sesdave; 27 August 2019, 14:00.
Originally posted by P911 View PostHi..I would like to know if this FW can be unrooted
Many thx!
Thanks,
Alvatech
Originally posted by sesdave View PostHi - why aren't there any display resolution options for higher than 1920x1080 or am I missing something.? My LED TV's are 4K capable. My matrix is set to 4k@30 but not options for higher resolution in Droid settings.
I haven't removed any resolution options from the system. Not sure what's going on. I will have a look later and see when I get this box connected to a 4K TV to check this out for myself. At the moment I'm not able to check into this.
Thank you,
AlvatechLast edited by ALVATECH; 29 August 2019, 04:07.
Thank you,
Alvatech
For the next update would be important and very helpful to get a zip_file which can be installed with the integrated TWRP without loosing the data (apps, configrations etc.)
The same as most custom roms of S912 or 905 have. Can you do this ALVATECH ?
I don't care much for OTA's you can read link down below about it. Also if you really wanted to you could always do a Data backup in TWRP and then flash new ROM and when finished just restore Data Partition only this would do pretty much the same. But be warned things can get messy. I might give it a shot but no promises, a lot has changed in Android Pie and OTA's.
Thank you,
Alvatech
Link:
[ROM] Beelink GT-King ALVATECH Standard Android (9.0 Pie) S922X This is a nice clean ROM with some tweaks, GUI cleanup, Mods and some changes made from the original GT-King ROM. Please read the entire first post before asking questions. Thank you. (There has been some hardware variants so please read carefully.) Best thing
Okay, I tested it and it works fine for me. My display options show up to 4K2K-60hz display. So must be something else with your setup. I have it set on auto switch to best resolution and it set it automatically to 2160p 60hz display mode.
Thank you,
Alvatech
Yup - I had set the 4k@60 on the wrong input source on the HDMI Matrix. Many thanks for showing the errors of my waysLast edited by sesdave; 29 August 2019, 12:58.
This can be done, but it would need to be done manually or you'll need to find an unsu zip file online and probably modify it to make it compatible for this box. Just a heads up I've seen users un-root their boxes for certain programs to work, and sometime even then it still doesn't help. Your best bet is to try to get Magisk going. As of right now I haven't had time to mess with Magisk to find out if it works or not. But from what I heard, Magisk doesn't seem to work yet for this box and I haven't had time to check into it. You might want to post on the XDA forum on the Magisk thread and ask there if it doesn't work for you. They're the ones that would be able to help better with this matter. Been pretty busy this week and still am, haven?t been able to get much done lately. If you?re still interested I can try to make you a zip file that you can flash in TWRP to un-root your box, when I get a little more time. Just PM me if you're interested.
Thanks,
Alvatech
Alvatech
There are currently 2980 users online. 0 members and 2980 guests.
