[ROM] Beelink GT-King ALVATECH Standard Android (9.0 Pie) S922X
Alfatech thanks for the firmware for the B922 there are things that are bothering: outwardly nothing is visible, but there are such crash records. Not found where to disable or fix?
I solved all the problems, don't worryYou may only view thumbnails in this gallery. This gallery has 1 photos.1 PhotoLast edited by dutch_; 07 August 2019, 03:42.
It looks like it's regarding the SystemUI which I didn't modify the SystemUI at all this is still from stock. It could of been something interfered with it and made it crash, then it started to log it. I will take a look and see if there is anything I can do. If you could please PM me or I will, so I can get some more info from you.
Thanks,
Alvatech
Originally posted by dutch_ View PostAlfatech thanks for the firmware for the B922 there are things that are bothering: outwardly nothing is visible, but there are such crash records. Not found where to disable or fix?
Funny? ...Xiaomi is the Manufacturer ?Kris....don't forget my boxes! Okay?
Originally posted by raruba View PostMy internet works great,(922x) all my boxes are wired. Must be a B922 problem
Originally posted by damians View PostIs the original belink firmware already pre-rotated? Good news I didn't know.
Thanks,
Alvatech
Yea, I wasn't immediately concerned with harm (Huawei?)... Just a point of interest.
I figured it a future solution referencing: "backing" into your L1 licensing protocols.
I anticipate like actions elsewhere.
Maybe......by accident, we'll benefit from better less-Beta based Roms ?
"Cus it Seems to me, that chip makers should... Cringe at the Crap SW laid upon their SOCs.
By extention, their reputation . Think not?
Yes, Beelink and other developers too use Xiaomi branding through out the ROM to help with WVL1 and other apps, no harm done to the box so it's okay.
Thanks,
Alvatech
F/QUOTE]
Originally posted by ClarkKent View PostYea, I wasn't immediately concerned with harm (Huawei?)... Just a point of interest.
Thanks,
Alvatech
Originally posted by tombraga View Post
No B922 problem - I got my box yesterday and Ethernet LAN is working perfectly, with nearly max speed about 92 MB/s off 100
http://www.bee-link.com/forum.php/fo...age%3D1&page=1
PS: the ethernet speed limit is 1000 and not 100.
Originally posted by ki69 View Post
IS not a B922 problem is a random problem that affect every box?s, the 922x also, has is reported in Bee link official forum:
So the ethernet works fine.
Don't make your personal problem to a general problem!
I was not talking about max. Box speed but about the max speed of my connected Router.
Even inCoreELEC forums users reporting problems with ethernet.
So if you don?t have a problem great! But if you can?t help, please leave to others that can help.
There are currently 2255 users online. 2 members and 2253 guests.
