TWRP is included with the ROM, and I see system/xbin/su... But no idea how to grant permissions. Any ideas or help?
[ROM] Beelink GT-King ALVATECH Standard Android (9.0 Pie) S922X
Installing SuperSU via TWRP or APK puts the device on a boot loop... Is that normal? I'm trying to install a few required apps that need superuser permissions, and having no luck figuring out how to do it.
ALVATECH as you already said, you will make an update for the B922 serie, as Beelink made an update this days also of their firmware.
You also informed, that you will not make yet a zip-file, only img file right? And you said, to keep all apps and configuration we could make with TWRP a backup only data and after the update of your new build then make restore of this data backup. So we don?t loose anything, yes?
And is it possible to flash then your new img-file with the TWTP which we have already installed? I would like to avoid to use USB Burning Tool, which was very, very tricky last time to connect with my laptop.
Originally posted by tombraga View PostALVATECH as you already said, you will make an update for the B922 serie, as Beelink made an update this days also of their firmware.
You're correct about TWRP backup. Also no you can not install a ROM img through TWRP. This is the whole point of using an OTA zip file. If you're having trouble flashing with USB Burning Tool then I would suggest to try the SD-Card method.
Thank you,
Alvatech
f you see that the device keeps connecting and disconnecting, make sure you're performing the order of operations correctly. I had to re-read the instructions because it kept popping up as a device, then disappearing. If you hit start before plugging in power/usb simultaneously, updating with the tool will work quickly and without any issues.Last edited by TraxtarXKR; 05 September 2019, 18:33.
Originally posted by ALVATECH View Post
Hello,
Thank you,
Alvatech
Not sure what you mean exactly. But to get my ROM installed it must be flashed completely first. The data backup is only for some of your settings you setup and apps for the most part. So if you're meaning installing Stock ROM then restore Data it will no longer have anything to do with my ROM, since data is only some settings and apps as I mentioned. If you can flash back stock ROM then there shouldn't be an issue flashing this ROM, since it gets done the same way.
Thank you,
Alvatech
I am on your build right now, ALVATECH and i wanted to update the firmware from Beelink and then (after making the backup again with new firmware) i will install again your rom.
So i restored with TWRP the firmware backup i had made before, everthing ok and i initiated the ota update with wifi connection and downloades 100%, all ok, then restarted to update the firmware.
But it goes to TWRP main menu and keep there,now updating automatically.
Before i instalalled your rom i the ota update which i made one time, worked perfectly, what can i do?
Originally posted by tombraga View PostI am on your build right now, ALVATECH and i wanted to update the firmware from Beelink and then (after making the backup again with new firmware) i will install again your rom.
Thank you,
Alvatech
Before i installed your rom, i had the TWRP only temporarely, not fixed installed. I always had to start the TWRP with official TWRP app.
This might be the reason, that before ota update worked, because it restarted to normal firmware recovery...
I like your rom and i already returned and i will wait for your update. I am happy with your rom, my idea was only to keep my firmware backup updated with newest firmware. But i don?t need it really, because i will go on with your rom,
Thanks for all.
Originally posted by tombraga View PostBefore i installed your rom, i had the TWRP only temporarely, not fixed installed. I always had to start the TWRP with official TWRP app.
Thanks for all.
Thank you,
Alvatech
I seem to understand you a little better now. Yeah it's because you didn't have TWRP permanently installed the first time around this is why. You could always wait for them to release an actual ROM img file and keep it for safe keeping if you like, I'm sure they'll be release something again soon anyways.
Thank you,
Alvatech
And i thought you will make un update of your rom based on this last firmware. Or you will wait for other update which they will release again soon as you said?
So you think, there will come other update soon? The last update from Beelink was few days ago, i think this https://forum.freaktab.com/forum/tv-...976#post782976
Thank you,
Alvatech
Hi ALVATECH , Thanks for your great works!! I am using a newly bought GT-King (S/N starts w/B922HQK) but it couldn't boot up successfully... I had once booted into the Android and see everything properly, but then it cannot boot into the home screen anymore - before I flash the ROM it keeps rebooting and showing Beelink's logo; after I USB-flash the ALVATECH (B922) ROM it stays showing the ALVATECH logo but never goes next (at least I have been waiting for 15 mins already...
Do you have any clue? I'm sure I didn't change any options about the ERASE ALL.
Thank you in advance~
Originally posted by andytplam View PostHi ALVATECH , Thanks for your great works!! I am using a newly bought GT-King (S/N starts w/B922HQK) but it couldn't boot up successfully... I had once booted into the Android and see everything properly, but then it cannot boot into the home screen anymore - before I flash the ROM it keeps rebooting and showing Beelink's logo; after I USB-flash the ALVATECH (B922) ROM it stays showing the ALVATECH logo but never goes next (at least I have been waiting for 15 mins already...
Thank you,
Alvatech
There are currently 4876 users online. 0 members and 4876 guests.
