[ROM] Beelink GT-King ALVATECH Standard Android (9.0 Pie) S922X
Yes I already have it ready to go but I've been having some issues with the newer SN: B922 boxes, and since I don't own or have this box physically in hand it makes it difficult to work without it. Still working on this and a few other projects at the moment. Not sure If I should just release the ROM's for both of these boxes without TWRP for now and when I get more time, I can send out a patch or another update later. Also I'm not able to replicate the issue with users that are having the language changing on their box, this doesn't happen to me on my box. So again unless I get my hands on a SN:B922 box I might be able to do something.
Thank you,
AlvatechLast edited by ALVATECH; 23 July 2019, 21:39.
Originally posted by sesdave View PostI for one would be happy with a custom ROM for SN:B922 box with or without TWRP..
I hope and plan on releasing the 2 ROM's tomorrow for the B922 & for the other boxes with the other serial numbers. I don't think I'm gonna have time today to set everything up but I might. I'll have TWRP on both ROM's too.
Thank you,
Alvatech
Originally posted by ALVATECH View Post
Hello,
Thank you,
Alvatech
I'm waiting on an em from gearbutts about this matter . I don't like mystery chip shipments!
...there goes buyers support on this box for sure.Kris....don't forget my boxes! Okay?
Originally posted by sesdave View PostAwesome - look forward to giving it a go.
Okay, everyone I have released a new ROM for the GT-King which is based off of the latest version from Beelink. I've also included TWRP , did some updates and did some other minor adjustments. Please read entire first post before asking questions. There is 2 separate ROM's depending on which serial number you have on the bottom of your box. They are both available for download on first post. I didn't do any major changes the main reason for the release was to support the new SN:B922 and add TWRP. But at the same time it also fixes the sound in Netflix.
Thank you,
Alvatech
Hi - just loaded it on my B922 box. Tried following the beelink flash instruction - no joy as box never came up recognised.in USB burning tool. The following posted by Boban.cro worked perfectly.
First open the burning tool, Upload the image file - when loaded press the start in the tool, Plug the dual USB cable into the PC. Next plug in box power connector and when the eyes turn green put the USB cable in the box USB 2.0 connector.- the one by the power socket .( Do not use the USB 3.0 on the box - it wont work). . You must be quick to connect the USB 2.0 .when the eyes turn green.
I tried doing it together as Beelink suggested - never connected. This worked first go.
Nice Rom - many thanks for your hard work.Looks clean . Runs smoothly - no glitches for me. Pretty zippy - stock Rom on the B922 got 127046 on Antutu. v7.2.2. This one 129349. Now I have a decent firmware its Hasta La Vista to all my RK3399 boxes for sure.
well maybe not if someone produces an Android 9 rom for my X99's
Originally posted by sesdave View PostHi - just loaded it on my B922 box. Tried following the beelink flash instruction - no joy as box never came up recognised.in USB burning tool. The following posted by Boban.cro worked perfectly.
Thank you,
Alvatech
Hi there, great job!!...I want to purchase this TV Box and I am wondering if some user has installed Magisk and removed Super SU and also has anyone tried and tested AutoFrame https://github.com/anpaza/afrd ?
Many thanks!
There are currently 4358 users online. 1 members and 4357 guests.
