Posted by Trebor
[ROM] Beelink GT-King ALVATECH Standard Android (9.0 Pie) S922X
Alvatech - are you going to create a new release soon incorporating any relevant changes in latest 904P0 rom.
Posted by Trebor
I've seen the update and I know of it. But still pretty busy at the moment and also there doesn't seem to be any major changes in the last update. I had recently posted that I'm debating to even make an update or wait for another update with hopefully something worth updating too. It looks like they will be hopefully fixing the status bar. If you look at link down below you'll see what they mentioned.
Thank you,
Alvatech
Link:
Originally posted by ALVATECH View Post
Hello,
Thank you so much for the Donation much appreciated. I have still been pretty busy so still haven't had a chance to get any update going. Not much changes with new update so debating to even release something yet or wait for hopefully a bigger change.
Thanks again,
Alvatech
Sorry not sure what's happening. You might try to reflash the box one more time, and if it continues to give you issues then you may have a faulty box. You may try SD-Card method if the USB tool isn't working for you.
Thank you,
Alvatech
Originally posted by johnsemple123 View Post
I (didn't think this would work as at first it wasn't)! but I did fix it I changed USB ports using the flash tool on my computer (strange I know) I did that and flashed official beelink firmware and it's back to the way it was from the beginning. PHEW again! NO more experiments I think!
Thank you,
Alvatech
I'm glad you got it going. Not sure why it was acting that way in the first place. But sometimes it can be USB ports, USB cables and or you need to uninstall and re-install the USB Burning Tool software again, this seems to work sometimes too.
Thank you,
Alvatech
I did follow instructions say erm put the USB cable into the USB 2 hub on the box and to safe myself put the other end into a USB2 port on my PC (Was not playing ball) but all of a sudden decided to change the USB port on the PC to one of my USB3 ports and voila) immediately started working. I might have flashed the firmware wrong too in the first place but I am back on stock and won't experiment again for a while incase next time i'm not so lucky!
Thank you,
Alvatech
Originally posted by sesdave View PostAlvatech - are you going to create a new release soon incorporating any relevant changes in latest 904P0 rom.
Posted by Trebor
https://beelink-my.sharepoint.com/:f...cLSbQ?e=Nrm3NV
Originally posted by raruba View Post
This Rom doesn't work on the S992X...I tried it, just a black screen.
Link for more info:
hi to all, I recently received my box king and today I tried to install this rom, unfortunately I had a lot of problems, USB burning tool 2.1.7 immediately recognized my box but at 3% it blocked me with an error " romcode / bl2 boot stage error "to install the rom I had to uncheck" erase bootloader "and now I have installed everything correctly. everything works but it does not seem normal to me that there is that error. can anyone tell me why or did he have the same problem?
Up. ? Is it a problem if I install the rom without erase the bootloader? it's the only way to install the firmware (I've tried other roms, including the last official one). if cue "erase bootloader" gets stuck at 3% with the error I mentioned above. Thanks.Last edited by mikehcl; 11 September 2019, 19:49.
This ROM is made for SN: B922 only. They haven't released one for 922X yet.
Link for more info:
https://forum.freaktab.com/forum/tv-...on-ddr4-v904p0
Originally posted by mikehcl View Posthi to all, I recently received my box king and today I tried to install this rom, unfortunately I had a lot of problems, USB burning tool 2.1.7 immediately recognized my box but at 3% it blocked me with an error " romcode / bl2 boot stage error "to install the rom I had to uncheck" erase bootloader "and now I have installed everything correctly. everything works but it does not seem normal to me that there is that error. can anyone tell me why or did he have the same problem?
Not sure why you got that problem in the first place. But you don't need to worry about unchecking bootloader issue you had, it's not needed. It could be what we had mentioned before, such as bad USB cable, USB port (maybe a different port works better USB3.0 on PC) and or uninstall and re-install USB Burning tool. It could of been any of these issues. But by unchecking erase bootloader this will not hurt your box.
Thank you,
Alvatech
Originally posted by kobo View Postis the notification bar problem fixed? also can i root with magisk?
Please read the following links down below.
Thank you,
Alvatech
Links:
[ROM] Beelink GT-King ALVATECH Standard Android (9.0 Pie) S922X This is a nice clean ROM with some tweaks, GUI cleanup, Mods and some changes made from the original GT-King ROM. Please read the entire first post before asking questions. Thank you. (There has been some hardware variants so please read carefully.) Best thing
There are currently 2432 users online. 2 members and 2430 guests.
