[ROM] Beelink GT-King ALVATECH Standard Android (9.0 Pie) S922X
But for GT mini you can find here perfect android 9 roms:
[ROM] Beelink GT1-Mini Volksware v.2.0_by_Sasvlad (Android 9.0) Hi, I present to you another ROM for this box. I've made 4 different ROM's for these boxes two for boxes starting with SN: 95X and another two for SN: B95 (English and Russian localization for each) Please download the correct ROM for your box. Changelog v2.0:
Hello, I got B922 version and I?m running on my 5Ghz wifi band very well. Besides that, I can reach and see 2.4 Ghz bandera, but no tries to connect to.
Hope this shed some lights on your issue.
I haven't had any issues with the either WiFi bands I've used both without issues. So not sure what's going on there. Also the 12hr format I have manually set this up through the ROM specifically. If you like you can PM me and I will be more than happy to assist you in getting that changed to a 24 hour format instead.
Thank you,
I hope for you consider adding that useful Clean memory button on your next update too.
And finally, 5GHz Issue, was something related between my old router and GT-King. Now it is solved due new internet service provider and new router too.
Thank you in advance Alvatech.
Thank you,
Alvatech
Originally posted by Activator View PostAlvatech, can this rom work on Beelink GT1 mini s/n 95X2 ?
Thank you,
Alvatech
Originally posted by NitroNipp View Post
Hello Alvatech, thank you for your gentle answer, Yes, I really would like you help me to change clock format, as soon as you have some time, Thank you.
Thank you,
Alvatech
Originally posted by mikehcl View PostA new firmware version for B922 has been released.
Thank you,
Alvatech
Rapidly following v904p0 the latest firmware release v905P0 which states in changelog that it address compatibility of ethernet card with certain routers. I haven't tested it yet but be nice to see latest version incorporated into any custom roms especially if it actually helps/solves the known ethernet issues.
https://chinagadgetsreviews.com/down...ng-tv-box.html
Originally posted by sesdave View PostRapidly following v904p0 the latest firmware release v905P0 which states in changelog that it address compatibility of ethernet card with certain routers. I haven't tested it yet but be nice to see latest version incorporated into any custom roms especially if it actually helps/solves the known ethernet issues.
I hope to release a ROM today, here very soon. Keep checking here and I hope to have it finished today.
Thank you,
Alvatech
Originally posted by raruba View Post
IS the LPDDR4 for the B992X? I have the 922X so I guess I use the DDR4 Firmware....is that correct?
Enviado do meu SM-G9650 atrav?s do Tapatalk
There are currently 2530 users online. 0 members and 2530 guests.
