[ROM] Beelink GT-King ALVATECH Standard Android (9.0 Pie) S922X
Originally posted by cmf View Post
Hi Alva, take your time! Family and Job has priority!!! I'm greatefull with this gift You give us.
I'm in no need to use Magisk, only for one of my local IP App that validates the ROM and says it's a modified one. But is not your ROM, with the original one I has have the same advice.
I',m wondering if there is a switch in this ROM that can mask ROOT. I asked it at beelink's forums, and moredator says "NO, ROMs originals comes ROOTED, and can't be masked."
I'm a noob here, and perhaps what I said here is terrible stuppid, just wondering.
Cheers.
cmf!
PD: Some strange characters appears when typing, anyone has noticed that?
you're good no worries. Hiding Root is what Magisk does, but as we know it's not working at the moment. I base my ROM's off of Beelink's ROM's so if their ROM's are rooted, usually I keep that way too. Even hiding root sometimes still doesn't work with certain apps checking / verifying different parts of the OS. Honestly if you installed Magisk and you mentioned that it removed root from your box. I think you can actually use that to un-root your box since it removes all rooted files, but then just remove / uninstall the Magisk app. That would actually remove root from your box to some extent. Yes, I've also noticed weird characters when typing. I think it's mostly through mobile phones and different web browsers on mobile phones. It doesn't seem to do this through a computer.
Thank you,
Alvatech
Originally posted by alok.droid View Post
Does anyone have any clue how to set permissions in an app to use root? for example I am using app Remodroid from play store.
I hope to make a patch for those who would like to add SuperSU to their devices. I'm currently working on another project and staying a busy with some other things, so I don't know when I'll have it ready exactly. But hopefully soon. You can try to add the app in the root of the OS under system/apps and add the proper permissions to the app and folder and then the app should work properly for you. If you need some additional help, feel free to PM me.
Thank you,
Alvatech
Not that it's this ROM specific but if you wanted to install magisk, you have to install it to recovery. Follow my instructions here.
Originally posted by ALVATECH View Post
No problem, on previous post you can see another user also commented on what you had asked. But if you do try, please let us know the results.
Thank you,
Alvatech
raruba I have the x88 king box as well, I would love to get a firmware that actually makes it work better, so far its been a week since I purchased it and while it runs stuff pretty fast, I can't get many apps to work on it. Netflix comes preinstalled but Amazon Prime, Disney Plus and even Angry Birds do not work on it. Stangely if you type π318 in the calculator it includes Kodi will install. It has no notification bar that I have been able to enable, and no root ability. Basically its as bad as my old 4.0 android box but that one at least works with many older apps. (Although Disney Plus is Android 5 and higher.)
I found a link to the current firmware on another site but this box is horrible. Here is the link to the original firmware:
Originally posted by greenstone View Postraruba I have the x88 king box as well, I would love to get a firmware that actually makes it work better, so far its been a week since I purchased it and while it runs stuff pretty fast, I can't get many apps to work on it. Netflix comes preinstalled but Amazon Prime, Disney Plus and even Angry Birds do not work on it. Stangely if you type π318 in the calculator it includes Kodi will install. It has no notification bar that I have been able to enable, and no root ability. Basically its as bad as my old 4.0 android box but that one at least works with many older apps. (Although Disney Plus is Android 5 and higher.)
https://onedrive.live.com/?authkey=%...126D253EA3A2B2
Originally posted by syked69 View PostNot that it's this ROM specific but if you wanted to install magisk, you have to install it to recovery. Follow my instructions here.
https://forum.freaktab.com/forum/tv-...971#post790971
Thanks again,
Alvatech
There are currently 2450 users online. 0 members and 2450 guests.
