I have air mouse, don´t know if this only hapens to users with Air mouse remote. This is annoing. Let´s hope some one can make a fix, because after 3 or 4 firmwares releases from beelink i don´t believe they are bothering to trying to fix it.
[ROM] Beelink GT-King ALVATECH Standard Android (9.0 Pie) S922X
Originally posted by ki69 View Post
Your are not alone with this. In oficial forum some of us question beelink, but is always the same i thing problem as introduced in 904 or 905 firmware, I almost certain that 903 don´t have it and for sure 902 that as the version that came with my replacement box don´t have this.
Hello and thanks for the amazing ROM!!!
Android TV newbie here.
When I press source button on my TV (simple tv not smart) my beelink turns on even tho the HDMI sec is disabled.
I apologize in advance if it's stupid question but it's really annoying and I couldn't find a solution.
That didn't happen with the stock rom..
Any suggestions?
Any suggestions?
I had already spoke to you through PM. Came to the conclusion that you probably had an older factory firmware on your box, and more than likely Beelink made some changes to the newer ROM that caused the issues with the HDMI CEC options.
Thank you,
Alvatech
Originally posted by ALVATECH View Post
Hello,
Thank you,
Alvatech
Can you, or anyone please put a link of your rom based on 905 firmware for B922?
Regards
I tried an older ROM from other Dev, and i can confirm that 905 firmware dont have this "always on bug".
Regards
Thank you,
Alvatech
I don't want to place that ROM to public anymore since it's an older ROM. But I will upload and PM you a link. If anyone else is interested please PM me. Like I mentioned I don't have this box at the moment, I loaned it to someone for a project they had and they are still using it. When I get it back I may have a look and do some comparisons to see what it might be. I really was wanting to take a break and been trying to finish off some things to do so. So hopefully Beelink is aware and can find a solution, best thing to do is to tell them about the issue.
Thank you,
Alvatech
As far as i see in beelink forum, they are aware of the problem but don´t fix it.
First i supose that as a problem of air mouse remote, because the box shutdown as as soon i use remote from tv ( sony, Phillips) it wake up again.
because they think that has the remote, thaey sayed that can´t do anything, because mayse the airmouse use the same remote code of known hardware, but the problem has not the remote, because after that post i see that the box restarts 10 seconds after i shutdown, even that i don´t touch the remote or have tv in standby.
Tks for your work, do what you have to do, because private/family life is first. And when have time, try to find a fix, because after 2 firmwares from beelink with this problem i really don´t believe they will fix this.
Regards.
Thank you Alvatech. As i remember the only problem with 905 has IPTV reboots. I hope no to get any.
Regards.
The issue occurs only on the newest rom official and Alvatech.
I turned off the box and then played with the tv controller (it's not smart tv) volume and settings button and nothing happened. The moment I press the Source button the box turns on so temporarily I first switch hdmi source (I have pc on the other port) and then I switch off the box via remote and it won't turn again, that's the temporary solution I found.
Mine is actually the non air mouse remote model.
Good to know about the 905 firmware is the last one before the disaster... gonna pm Alvatech
Alvatech no pressure....I'll stick to the old ROMs for now, it would be sweet if you can take a look when you have some time, because so far Beelink provide problems not solutions.
Thank you, I had a feeling I'm not the only one, or that it comes from my end somehow, especially when it comes to such a terrible company.
Originally posted by Jasonsyna View PostHi ,
I have the Gt king b922 and i cant passthrough dolby hd or dts hd via kodi. I have a denon receiver. My old gt1 ultimate can passthrough without a problem doldy hd . Any solution?
Been running the awesome mod Sasvlaid on a gt king . The ? I have is it normal for the video to quickly blink off and then on again ? It has a slight hesitation intermittent at times. But not all the time ! Is there anyone else experiencing this same occurrence ? Thanks in advance for any input or maybe a solution ! Note : It does this from start up , on every app, and when video is playing. Sometimes it doesn't do it at all. I know I'm a newbie here but I've been testing for over 20 years. Just wanted to check an see if it's a glitch in the Rom or maybe a bad box or just $?!t happens.Last edited by rickg007; 01 March 2020, 22:55.
Originally posted by rickg007 View PostBeen running the awesome mod Sasvlaid on a gt king . The ? I have is it normal for the video to quickly blink off and then on again ? It has a slight hesitation intermittent at times. But not all the time ! Is there anyone else experiencing this same occurrence ? Thanks in advance for any input or maybe a solution ! Note : It does this from start up , on every app, and when video is playing. Sometimes it doesn't do it at all. I know I'm a newbie here but I've been testing for over 20 years. Just wanted to check an see if it's a glitch in the Rom or maybe a bad box or just $?!t happens.
Thank you,
Alvatech
There are currently 1948 users online. 2 members and 1946 guests.
