[ROM] Beelink GT-King ALVATECH Standard Android (9.0 Pie) S922X
Hello Alvatech,
Tried to install GT_KING_C92X_AT_V6.0 version but after downloaded from MEGA and unRARed the img file seems copprupted. Also the Burn Card maker shows the following error " Check Uboot file after read failed"
Can you please check the above version on MEGA? Seems something happened with...
Thank you in advance!
Hello Alvatech,
Thank you so much for your software contribution and your time invested in this ROM.
I have a simple question for you - is there a way to check what ROM version I have installed on my device? I've been a little scatterbrained lately(lol), and can't seem to remember when exactly I installed in on my device (before or after the 30th of November when you posted that there was a update available with some changes).
Hope you keep up the good work. Cheers!
Dont know what is the issue. Serial no of my box is SA9XH0EF70069.
Thans if you have some suggestions what I did wrong...
Originally posted by Carlos Casalta View PostHello
I bought the gt king pro.
Today I flash the rom of alvatech
My Bluetooth doesn't work. The icon stays "on", but Bluetooth keeps disconected
Any way to put this on?
Originally posted by raruba View Post
Try Using Alvatech's vendor (here) with SlimBox's System, v10.4.1 for the X88 King, I did on mine and it works like a charm. I got the BeeLink GT King sn:922X. Good Luck. Also have the X88 King box.
But where I can find it? You said "here". Dou you can post the link, please?
My box SN is SB9H
Originally posted by nextman View Post
hi are you saying you have flashed Slimbox for the x88 on a Beelink GT King? I have a B922 GT King, would love to try slimbox on it. I already have slimbox on a x96 Air and it's perfect.
Thank you,
Alvatech
Link to Alvatech - King Pro ROM:
This is a nice clean ROM with some tweaks, GUI cleanup, Mods and some changes made from Beelink's stock ROM. Two different ROMs one for the GT-King Pro (SN:922H) and another ROM for GS-King X / GT-King Pro boxes (SN: C92H, SA9H, SB9H, 6B9H). Please read the entire first post before asking questions. Thank you. Changes/Mods
Originally posted by ilu213 View Posthello,
can i use split screen using this rom ? because on the default rom, it s not posible
thanks
I personally don't have any use for split-screen or have even tried. So I couldn't tell you. This ROM is based on the original ROM from Beelink. So, if it doesn't work on there then more than likely it won't work on this ROM either.
Thank you,
Alvatech
Shame, Beelink needs to up their game a little. Definitely a tool for 2020-2021.
Split screen is great way to study/ learn. Books or tech manuals on one side and video or zoom on the other.
PIP is not as useful in this regard....though it's convenient when reading and semi-watching junky movies.
There are currently 2263 users online. 0 members and 2263 guests.
