[ROM] Beelink GT-King ALVATECH Standard Android (9.0 Pie) S922X
Guest
Hola Alvatech. Hoy recibí mi King Gt Pro, estoy muy feliz, lo primero que hice fue cambiar la Rom a Alvatech. Mi pregunta es, en el futuro, ¿estará disponible el sonido HD en Kodi? Solo puedo obtener sonido Dts y Dolby Digital, pero no Dts Master Audio y True Hd. ,
Tu trabajo es maravilloso. Sigue así. Felicitaciones
Hi guys, first post in here. I am having wifi issues with the new SB9X version. I have two boxes with similar issues; one says wifi not connected while the other disconnects within 20 minutes. With the latter, I must unplug/plug back in to gain access to wifi networks.
I downloaded Alvatech's GT_King_AT_V5.0_B922 and GT_King_AT_V5.0_C92X but it did not rectify the issue.
Any help would be much appreciated!
Originally posted by newer View PostMy GT-King Pro sn# SA9H with file i use?thanks
This is a nice clean ROM with some tweaks, GUI cleanup, Mods and some changes made from Beelink's stock ROM. This ROM was converted into Android TV. If you're looking for a Standard Android ROM look here (https://forum.freaktab.com/forum/tv-player-support/amlogic-based-tv-players/s922x/others-s922x/firmware-roms-tools-dq/787817
You're on the regular GT King thread, SA9H is in GT King Pro thread above
Originally posted by jjbaker14 View Post
Use C922H & SA9H file from this link
I have an issue with the original Beelink firmware 912P0.
I wonder if this ROM fixes it.
The problem is the following:
Beelink interface is always displayed at max resolution (4k) and for some reason the TV (LG Oled) blinks a lot (is black most of the time) and I have to fight with the Beelink android to reduce the resolution so that I have a stable image and see anything-
“Droid settings > Display > Screen resolution”
(This only happens when running Android. When booting with CoreElec I can watch 4k videos without any problem, so the issue should be software related).
Problem is it never preserves this setting. When I restart I have to go through this all over again. I want it to boot with a lower resolution, say 1080p60hz, but it always boots at 4k.
Do you also have this problem with this ROM. Was it fixed somehow?
Does your box preserves the screen resolution when booting Android?
Hello everyone,
It has been a while. I've been pretty busy with lifestyle changes and other projects. I've updated the first post with the latest ROM from Beelink. I hope you'll enjoy the new updated ROMs. I don't have as much free time as I use to, so please try to help each other with any questions in my absence. I hope to update the 2nd post with some updated info on how to pass safetynet. Also, to fix a screensaver bug I've just noticed at the last minute (I'll give instructions on how to fix it pretty quickly). I hope to release Android TV ROMs next for these boxes.
Stay safe and thank you,
AlvatechLast edited by ALVATECH; 01 December 2020, 05:29.
Alvatech
There are currently 2174 users online. 1 members and 2173 guests.
