[ROM] Beelink GT-King ALVATECH Standard Android (9.0 Pie) S922X
Thanks for the reply sir. I just didn't know if it was just me or if anyone else was experiencing the blinking. Since you have I will just live it. It's only anoyying at best. Like I said it only happens intermittent. Not all the time. I may just for kicks test another rom , but I really like the look of the shield on Sasvlaid's rom.
Originally posted by rickg007 View PostThanks for the reply sir. I just didn't know if it was just me or if anyone else was experiencing the blinking. Since you have I will just live it. It's only anoyying at best. Like I said it only happens intermittent. Not all the time. I may just for kicks test another rom , but I really like the look of the shield on Sasvlaid's rom.
I misworded about the blinking sorry, meaning I haven't noticed any blinking. But either way it would always be best to try and see for yourself because of the different boxes (different hardware variants). Also I think you're referring to Android TV version. Most developers make 2 versions, one Standard Android and the other Android TV version. The Android TV version is more like the Shield, but still with limitation because of the box not being certified. I've also made 2 different versions, you can find it here on FT, you'll need to decide what works best for you. Also your blinking could be caused by the AFR'd app made to change resolutions. I'm pretty sure I've seen people complaining about it in the past.
Thank you,
Alvatech
Originally posted by tredn View PostHello!
Does this device support NFS network protocol? Is it possible to activate it?
I don't think it's an option of the Android OS in general. I personally don't use any of that. But I'm sure you can find a third party app for what you're trying to accomplish. You may want to start a new thread and ask other users if they have any ideas as to what you're trying to accomplish.
Thank you,
Alvatech
Originally posted by tredn View PostThank you for the answer! One more question - is it possible to install Xposed on this ROM?
Thank you,
Alvatech
Originally posted by ALVATECH View Post[ROM] Beelink GT-King ALVATECH Standard Android (9.0 Pie) S922X
This is a nice clean ROM with some tweaks, GUI cleanup, Mods and some changes made from the original GT-King ROM.
Please read the entire first post before asking questions. Thank you.
(There has been some hardware variants so please read carefully.)
Best thing to do before flashing your box is to check which Serial Number you currently have on the bottom of your box.
I've made 3 different ROM's for the following boxes starting with SN: 922X &SN:95X2 another for SN:B922 and SN:C92X & SA9X.
Please download the correct ROM for your box down below.
Why does the Enter key on the USB keyboard not work properly when entering a web address in the browser address bar, and when the virtual screen pops up, the Enter key on the keyboard and the left mouse button do not work properly. Can the Enter key of a USB keyboard work normally at all times, and when the virtual keyboard pops up, the left mouse button can be directly clicked on the virtual keyboard to input?
By the way, the my TV box SN is B922,and I tried to change the files such as gnaric.kl on the TV box where the keyboard and mouse are working normally, and it didn't make the keyboard and mouse work properly on BEELINK GT King.
ALVATECH
Thanks for this fantastic ROM.
Is there a way to get Titanium Backup to work, I use latest version 8.4.0.2 and it always get force close, maybe an older version works?
How can I uncompress the img file of a firmware, because I want to extract the orginal widget for the ram cleaner from orginal firmware?
Best Regards
Best Regards
Originally posted by lin20121221 View Post
This is a good ROM, thank you very much. I have a few questions about the external keyboard and mouse:
Something that may Interest User of the Beelink boxes:
BeeLink: EmuELEC: Shantigilbert's box-integrated simulator (Jing Chen) EmuELEC system installation tutorial: https://i.imgur.com/2l5VXfI.png Some time ago, we officially launched the GT-King series dual system, which comes with an SD card with CoreELEC system, and supports the system to switch between Android AOSP and
Have a look
There are currently 2349 users online. 3 members and 2346 guests.
