If so what was the previous version of chrome which was used in 3.1 ROM
[ROM] Beelink GT-King ALVATECH Standard Android (9.0 Pie) S922X
Thank you,
Alvatech
Originally posted by Normo View PostHi Alvatech
I was just wondering if you'll be doing the rom for the new beelink gt king serial number SN:C92X ?
The main reason for that 907P0 version is to have dual boot with CoreElec so at the moment I haven't had time to look into it. If you're interested in dual booting into CoreElec then I would say give it a try. But if you have no interest in CoreElec then there is really no reason to get it updated to this newer firmware version. When I get some time I might look into doing something with it. But at the moment I'm working on a few other projects. trebor had also mentioned that it seems to only be a reference to the newer Dual Boot with Android/CoreELEC.
Thank you,
Alvatech
Originally posted by ki69 View Post
Great is good to know, that this is equivalent of B922 Rom version.
If the ethernet bug is a firmware problem from Beelink, and if Onsmart eventualy release a firmware update, i can use it to Gt king. Or better, some of the devs use it as base of costum firmware.
But one issue i got with both, the wifi is only connecting with 2,4GHz frequency band with a speed of only 144 Mbit/s. Does anyone have the same issue or an advice solving it? Thanks
Originally posted by Chrisme View Post
For everyone have an Orbsmart S86, I've installed the X922 instead of the B922 and doesn't have problems until now.
I dont know what it is happening
The same speed in 2.4 GHz and the 5Hgz has just dissapeared, well never it worked
Originally posted by pulsatioflamma View PostWhat about SN: C922H?
You can use the B922 version for your box if you'd like. The difference is the CoreElec setup in your boxes SN. So if you don't care for CoreElec then you don't need to worry about it, and you can use the B922 ROM.
Thank you,
Alvatech
Originally posted by liucifu View PostWhat about SN: SA9XHQ....?
that serial number I'm unaware of and I don't see it on Beelink's website. You might ask Beelink for a link to the ROM / Firmware, and also ask them if there is a current firmware that is compatible.
Thank you,
AlvatechLast edited by ALVATECH; 18 December 2019, 21:52.
Originally posted by Cafpy90 View PostQuestion... Does the android tv remote from the playstore (the generic one) work with this rom?
I hate using a keyboard to type stuff, and would much rather use my phone so this would be a god send!
Thanks guys!
yes the Android TV Remote app works with this ROM.
Thanks,
Alvatech
There are currently 1864 users online. 0 members and 1864 guests.
