[ROM] Beelink GT-King ALVATECH Standard Android (9.0 Pie) S922X
Originally posted by ClarkKent View Post
should not, don't wipe the data. You're not running a custom recovery or a backup app?
Any guidelines how to properly backup/restore apps and data on this rom?
Originally posted by Schrauff View Post
I have backed up all partitions in TWRP before flashing with USB tool, after flashing v5.0 ROM I restored only data Partition. All installed apps are there, but the box can't connect to wifi anymore.
Fresh back-ups once your "settled in". And load a real back-up apk for redundancy, I am well pleased with Titanium BkUp Pro.Kris....don't forget my boxes! Okay?
Originally posted by sesdave View PostLike the latest firmware - nice job. Now this is more like the box it was always meant to be
Alvatech
Thank you,
Alvatech
Originally posted by ALVATECH View Post
Thank you!!
Alvatech
Not sure why this is happening. If you used the original TWRP that's in this image it should work. Unless you changed out TWRP that could be the issue. I restore Data and Cache all the time without any issues. You might try again, and If your WiFi works before any restore then more than likely it's something in your backup it doesn't like.
Thank you,
Alvatech
Download latest stock ROM
http://www.bee-link.com/forum.php?mo...extra=page%3D1
Follow flashing guide using USB burning tool on first page of this thread.
Downloaded b922 and it works about 10 times faster than the latest beelink firmware. Thanks for all your effort. I seem to have one remaining bug which I have noticed many people have a problem with. The power button on the remote will switch off the box but will not switch it on. My remote is a G10s Voice Air Mouse Remote 2.4Ghz. I have also tried a bluetooth remote but it will not pair with the box. Any advice would be appreciated or can you recommend a remote where the power button works properly.
many thanksLast edited by Scottuk2017; 25 January 2020, 12:29.
Originally posted by Scottuk2017 View PostDownloaded b922 and it works about 10 times faster than the latest beelink firmware. Thanks for all your effort. I seem to have one remaining bug which I have noticed many people have a problem with. The power button on the remote will switch off the box but will not switch it on. My remote is a G10s Voice Air Mouse Remote 2.4Ghz. I have also tried a bluetooth remote but it will not pair with the box. Any advice would be appreciated or can you recommend a remote where the power button works properly.
many thanks
After the lastest oficial update the sd Update don´t work because it enter bootloader menu insted of direct firmware update,, is any other option without usb male2male cable? for the direct update from pc?
With twrp is easy just update with zip file, but with normal bootloader i can´t update from SD.
Edit: the problem has the tf card. Change it and worked.Last edited by ki69; 27 January 2020, 00:56.
many thanks
if you're using an aftermarket remote you would need to program the G10s remote from factory remote since the power button works with the IR to power on the device. I don't own this remote but I do know the factory remote powers the box on and off just fine.
Thank you,
Alvatech
Hi
Yes thanks for that ,yes it seems I will buy an original beelink remote as no others will work because it needs to read the codes from the original remote. I have seen a screenshot of a meassage that keeps coming up every now and again. How can I fix what is wrong as I have no idea what it means.
There are currently 2861 users online. 1 members and 2860 guests.
