[ROM] Beelink GT-King ALVATECH Standard Android (9.0 Pie) S922X
Hi just flashed my box with burning 3.1. Load the rom img on tool once loaded hit start button - important wont flash if you dont. At this point the gt king is not powered on. Plug dual usb lead into PC - Insert the other end into usb 2 beside the power socket on box.- Do not push it in to connect - just hold it there. Push in power lead - when eyes turn green push in the inserted USB immediately. Flash will start.
Originally posted by sesdave View PostHi just flashed my box with burning 3.1. Load the rom img on tool once loaded hit start button - important wont flash if you dont. At this point the gt king is not powered on. Plug dual usb lead into PC - Insert the other end into usb 2 beside the power socket on box.- Do not push it in to connect - just hold it there. Push in power lead - when eyes turn green push in the inserted USB immediately. Flash will start.
(0*32030201) Uboot/Get result/DiskInitial error
I am afraid this is physical damage of disk.
Does anyone have photo which pins I need to connect to reset NAND flash?
Although, because computer already recognize TV box, I don't have much hope.
Originally posted by lovacuzitu View Post
Did all the same. But keep getting this message at 7% of flashing process:
I got my gt king pro today, i am not a professional, so i hav 3 questions please.
1.is it normal that my box CPU is only up to 1800MHz and not 2.2MHz?
2. Can I get rid of root? Because i have a streaming app that does not support root
3. How i use Disney +? When i sing in, the app closes itself
Thanks in advance
Maybe try SD flash if you can get into recovery mode
https://forum.xda-developers.com/and...reset-t4050175Last edited by sesdave; 15 May 2020, 05:09.
Originally posted by sesdave View PostMaybe try SD flash if you can get into recovery mode
I can't get into recovery mode. When I plug in power cable there is no green skull, only red. It doesn't even start to boot. My only hope is shorting pins, but I don't know which ones.
Originally posted by Shark91n View PostI got my gt king pro today, i am not a professional, so i hav 3 questions please.
Thanks in advance
Yes, the CPU clock is done from Factory. If you like speak to Beelink on their forums for issues you may have with that.
Please read entire first post and then also 2nd post on how to hide root and other tips for Disney+.
Thank you,
Alvatech
Originally posted by raruba View Post
Here try this. https://www.bee-link.com/forum.php?m...d=51263&extra=
Originally posted by sesdave View PostMeant to be a picture here showing pins to short. I cant see it - I presume need be lodged into beeline
There are currently 1847 users online. 0 members and 1847 guests.
