[ROM] Beelink GT-King ALVATECH Standard Android (9.0 Pie) S922X
I loaded ROM GT-King_Pro_AT_v3.0A_ATV_C922H and everything worked great. However I downloaded two IPTV programs Tivimate and Perfect Player. Neither one will connect and populate the channels. I have another box and it is working without the custom ROM. I have double checked the urls. When I load Perfect Player it shows downloading the channels and EPG but they do not apear. Is this ROM able to be used with a IPTV program or am I missing something?
Originally posted by arms View PostI loaded ROM GT-King_Pro_AT_v3.0A_ATV_C922H and everything worked great. However I downloaded two IPTV programs Tivimate and Perfect Player. Neither one will connect and populate the channels. I have another box and it is working without the custom ROM. I have double checked the urls. When I load Perfect Player it shows downloading the channels and EPG but they do not apear. Is this ROM able to be used with a IPTV program or am I missing something?
Originally posted by jmtorres View PostThanks for room Alvatec,
Thank you,
Alvatech
Originally posted by raruba View Post
Thanks for your hard work Alvatech, great Rom.
AT in these ROMs stand for AlvaTech, and ATV= Android TV.
Hope to have some ATV version out very soon.
Thank you,
Alvatech
Originally posted by ALVATECH View Post
You're welcome!!
Thank you,
Alvatech
You're welcome, it's been a while....
Thank you,
Alvatech
Originally posted by bg_man View Post
Its working for sure. Seems like a configuration issue. Some IPTV providers require specific MAC address or a client string, some providers limit the number of concurrent connections.
I am using GT-KING_AT_V5.0A_B922 ROM in my box. I have some wifi issues, because my box cannot connect to any Wifi network (I am using Ethernet cable). I have two questions:
1. Is the latest V6.0 ROM contains any improvements related to the Wifi?
2. How can I update my current V5.0 ROM to V6.0 ROM without any loss. I mean installed apps and whole settings of the Box. Is it possible or should I configure everything again?
Thanks!
Hello,
The best thing to do is to try it out on your box and make your own judgement. If Beelink's original firmware doesn't improve WiFi then I doubt this will. Also, I'm sure I posted somewhere here on how to backup with TWRP so you don't lose settings. But to be honest, the best thing to do is to re-flash your box and start all over as you may have issues restoring data and things not being compatible.
Thank you,
Alvatech
Thanks for the ROM Alvatech!
Issues:
Wifi on B922 can't connect for me as well.
At least one setting doesn't keep after restarting. Zoom in and out for the screen positioning. My setup is with Magisk and I do "reboot recovery" in order to keep Magisk. I haven't look at any other settings yet.
Did your rom supports PiP? I wasn't able to find this functionality in any Rom for this box and I wasn't able to run it in your implementation. TiVimate, e.g.
A request:
Could you include cifs kernel module in the next version?Last edited by bg_man; 08 December 2020, 23:20.
Hello everyone,
I have updated the 2nd post with some updated info on how to pass SafetyNet and a few other tips. I have now released 2 different types of ROMs one being Standard Android and the other one being Android TV. Thank you everyone for all the positive vibes/feedback and also donations I really appreciate it.
Stay safe and thank you,
Alvatech
Originally posted by bg_man View PostThanks for the ROM Alvatech!
Issues:
A request:
I think I solved the Wifi and Bluetooth issue!!! Try to pull out everything from the USB 3.0 ports. After that the Wifi 2.4 Ghz and the Bluetooth connections working well!
There are some interference in my opinion.
Is it possible to watch Netflix and prime video in hd with this rom?
Also, can updates be flashed via twrp without losing data? Or the rom supports OTA updates?
Hello,
These boxes are not Certified so you can not view this content in HD for the two mentioned apps.
Also, you can try to do a backup of your data partition with TWRP and then restore once you flash the ROM onto your box.
I personally don't recommend it because of the issues that may arise in doing so. Please look online for tutorials if needed on how to use TWRP if you're interested in doing this.
Thank you,
Alvatech
There are currently 3730 users online. 0 members and 3730 guests.
