[ROM] Beelink GT-King ALVATECH Standard Android (9.0 Pie) S922X
Originally posted by raruba View Post
Thanks, I might give that a try....will let you know.
Still don't work, it loaded but knowing worked...USB's Mouse etc.
It seems that the only thing that dont works are the usb. I'd tried and Lan, wifi, bt, Ir... and all works, storage show 128Gb too. Would be wonderful if someone can make a patch to make usb works. I downladed an app from play store to see usb devices and seems that both are reconogised but no input or storage devices work. I post the log.
Device Info
Device Path: /sys/bus/usb/devices/usb1/
Device Class: USB Hub (0x9)
Vendor ID: 1d6b
Vendor Name (reported): Linux 4.9.113 xhci-hcd
Vendor Name (from DB): Linux Foundation
Product ID: 0002
Product Name (reported): xHCI Host Controller
Product Name (from DB): not found
Additional Info
USB Version: 2.00
Speed: 480
Protocol: 01
Maximum Power: 0mA
Serial Number: xhci-hcd.0.auto
Device Info
Device Path: /sys/bus/usb/devices/usb2/
Vendor ID: 1d6b
Product ID: 0003
Additional Info
USB Version: 3.00
Speed: 5000
Protocol: 03
Maximum Power: 0mA
Thanks in advance
Originally posted by Juasser View Post
For x88-King
Device Info
Vendor ID: 1d6b
Product ID: 0002
Additional Info
USB Version: 2.00
Speed: 480
Protocol: 01
Maximum Power: 0mA
Device Info
Vendor ID: 1d6b
Product ID: 0003
Additional Info
USB Version: 3.00
Speed: 5000
Protocol: 03
Maximum Power: 0mA
Thanks in advance
If you could please start a new topic / thread for your box. I would like to keep this thread about this ROM (GT-King) only please.
Thank you,
Alvatech
Originally posted by elmik View PostHi
I have problem with burning, on SD card maker have error fail to extract bootloader.partition.
And on usb burning tool: parse burning image fail.
What can I do?
I have personally downloaded this ROM again just to test this and I have successfully made an SD-Card with the Burn Card Maker Tool without any errors. You might have a corrupted image. Please try to download the ROM again and also make sure you extract the ROM / image from the zip file before making the SD-Card or trying to flash it to your box.
Thank you,
Alvatech
Originally posted by ALVATECH View Post
Hello,
Thank you,
Alvatech
You're welcome I'm glad you like it!
Thank you,
Alvatech
He instalado varias veces las PLEX de PlayStore y de Aptoide y no hay manera de que funcione bien, como la que traia la ROM original , la PO3 de Beelink.
¿Es posible que tu puedas extraerla de la ROM ORIGINAL PO3?
Originally posted by SERCOPA View Post
Hola ALVATECH, tengo un problema, desinstalé la aplicación PLEX de la ROM original, es un PLEX diferente al que se puede encontrar en PlayStore .
Descargando la imagen original de Beelink y con las Amlogic tools de Ricky Divjakovski puedes sacarla. Lo que no se es si trae alguna libreria adicional que debas copiar también, que puede que sea tu problema.
English please ,
greetings / gefattern
You can extract the ROM image using an Amlogic Tool. Then use that tool to get the apk needed. I have put the following link down below.
Thank you,
Alvatech
Link to extract ROM:
Hi, I have exactly the same problem, which is:
I've formatted an SD card with SDCard method but when rebooting the GT King it starts in normal mode and not in recovery mode flashing the rom. If I push the pin it starts in recovery mode / boot options .... but it does nothing. The SD card is detected as I can browse it via file manager.
Maybe I miss something, I don't know, can you please help me?
Hi, can you please help-me?
I just bought a Beeling GT King a few days ago.
But when i connect a pen drive to the box and start watching a movie with the default movie player, or other player like MX etc, after a couple of minutes the video playback just stops, and the box stops responding... I've checked and the box is running the latest firmware....
did you ever saw something similar? how can i fix this? or should i return the box to the vendor?
thanks a lot.
kind regards
There are currently 2328 users online. 0 members and 2328 guests.
