[ROM] Beelink GT-King ALVATECH Standard Android (9.0 Pie) S922X
Okay, everyone I have released a new ROM for the GT-King which is based off of the latest version from Beelink at the time of writing. I did some updates to the ROM and did some other minor adjustments. Please read entire first post before asking questions. There is 2 separate ROM's depending on which serial number you have on the bottom of your box. They are both available for download on first post. Let's please stay on subject when asking questions. If it doesn't pertain to this ROM then please search other threads for answers, if not you can start a new thread.
Thank you,
Alvatech
Originally posted by JOKERPT View Postnice work!!
I have the box SN: B922
I start the box with the reset pressed, the logo of beelink appears and after a few seconds the screen goes black and nothing happens help please
thanks
I would need a little more information in order to help. Are you trying to flash the box with an SD-Card or are you trying to get into TWRP? If you're flashing with an SD-Card make sure you prepare the SD-Card properly and then keep the box plugged in to an HDMI port while you do the procedure so you can see the process start. You'll see the flash process status bar moving at the bottom, this will help you indicate that the box is being flashed. If for some reason you switched to another source on the TV / Monitor then sometimes the box can lose signal while you're in recovery mode. If you're flashing with USB Burning Tool please read the entire first post for instructions.
Thank you,
Alvatech
Originally posted by ALVATECH View Post
Hello,
Thank you,
Alvatech
trying to flash the box with an SD-Card and use the burn card maker v 2.0.2 to prepare sd card
I've personally just re-flashed the box with an SD-Card to make sure everything was working fine. I used the same burn card maker and flashed it without any issues. Best suggestion would be to try again. Like I've mentioned try to keep HDMI cable plugged in and don't switch to any other sources. Then make sure as soon as you see the Android logo with status bar at bottom let go of reset button. If for some reason you still don't see anything just leave the SD-Card in the box and wait for about 15 min to be safe and it should automatically restart if you setup your SD-Card this way. There is an option for reboot, make sure that check box is checked when making SD-Card image.
Thank you,
Alvatech
Hello,
Thank you,
Alvatech
check box yes to reboot, partition and format and erase bootloader.
chose erase in normal
tomorrow i will try with another sd card...
Made the update now, thanks for the work, ALVATECH
the idea with data TWRP worked, but with some apps (Kodi for ex.) i lost the installed addons and configs. Also with Titanium Pro restore of the Kodi app, which i had done too, i lost the data.
But was worthy to make the update now i can see my bar above and can push it with my mouse.
But when i want to close the open apps, before i could wipe with the mouse each open single app with the mouse to close (for example to the right side), now its not possible more, only to close all open app with the x.
why you changed this???
Hello,
Installing the firmware with USB_Burning_Tool I accidentally damaged the bootloader I think I bricked it, someone can help me Where are the contacts for the short circuit using the "Short Pin" method or are there other methods? It is no longer recognized by the PC and I also tried with sdcard but nothing to do .. !!
There are currently 4568 users online. 0 members and 4568 guests.
