i think, i soft brick my am6. anything that can restore back without using usb burning tools?
[ROM] Ugoos AM6 ATV_by_Sasvlad ( AndroidTV 9.0 )
Originally posted by owhbaem View Post
i got this error 0x10401001 Romcode/BL2_boot stage error, at 3%
https://androiddatahost.com/wp-conte...l_v2.1.7.3.zip
Are you using a thick USB A Male to USB A Male Cable
Using Windows 8 and not Windows 10?
Try to load an earlier firmware and also connect the power cable quickly.
I also got an error once when I connected the powered power cable slowly lastly.
Or use
Are you using the latest flash tool?
Or use
https://chinagadgetsreviews.com/down...er-v2-0-2.html
??????all well now. maybe im pressing wrong button.
first, im flashing update through usb by stock recovery. after success, im able to boot+ i see magisk not install.
??????after that i shut down and pressing the maskrom button. im flashing ATV_by_Sasvlad. all downloaded file are gone (i dont care much) its like new again. thanks a lot for giving support mo123
If you want to make a backup of your apps and their data to easily restore later if you do a full reflash, you can try
https://apkpure.com/migrate-custom-r.../balti.migrate or
F-Droid is an installable catalogue of FOSS (Free and Open Source Software) applications for the Android platform. The client makes it easy to browse, install, and keep track of updates on your device.
Then save it on a flash drive to have a backup.
Originally posted by Sasvlad View PostUpdated to AM6 Android TV+CoreElec by Sasvlad 0.2.8+ Dualboot
How to install Magisk on the AM6
1) Under Ugoos Settings - Choose Root with SuperSU
2) Now restart your device
3) Install Magisk Manager
https://github.com/topjohnwu/Magisk/releases/download/manager-v7.5.1/MagiskManager-v7.5.1.apk
4) Restart your device
5) Open Magisk Manager and grant it root permission with SuperSU
6) In Magisk Manager's Settings choose Magisk Core Mode Only and enable it
7) Restart your device
8) Open Magisk Manager and under Advanced Settings(You need to use an airmouse or USB mouse)
choose only the 'Recovery Mode' checkbox and uncheck 'Preserve AVB 2.0/dm-verity'
9) Now click on Install at the top right next to Magisk and select 'Direct Install'
10) Wait for it to finish and then manually restart your device by long pressing the power button on the ir remote and choosing Restart'
11) Magisk will now be installed
12) In Magisk Manager's settings, disable the Magisk Core Mode Only so it uses the full Magisk Mode now
13) Also disable SuperSU root now from Ugoos's Root Settings
14) Reboot
Magisk should now work fully and you can hide root from apps or make your device Google Certified by using theMagiskHide Props Config module.
You can use a root file manager and delete the system/xbin/su file to not interfere with Magisk root.
In order to avoid a misunderstanding I have a question regarding this procedure. As far as I understand choosing the 'Recovery Mode' as installation mode means that you have to reboot into recovery evertime when you want to use Magisk - is that correct?
In step 14 you mentioned only to reboot (without a hint to reboot to recovery) - that's a bit confusing for me.
Thank you very much in advance for clarification!
Best regards
eseze
Originally posted by eseze View Post
First of all: THANK YOU VERY MUCH for this description!
Best regards
eseze
Magisk works after every power on or normal reboot.
You don't need to boot to recovery or anything.
So enjoy it
There are currently 2361 users online. 0 members and 2361 guests.
