[ROM] Ugoos AM6 ATV_by_Sasvlad ( AndroidTV 9.0 )
    Originally posted by Hitachi View Post
    Hi dev.
    I have a problem about safety net on magisk.
    any advice?
    thnks
    Use the Magisk Hide Props Config module to emulate a Xiaomi Android 9 device.
    You will need a terminal app to do the steps.
    eg. type props in the terminal app.
      https://apkpure.com/terminal-emulato...al.androidterm
      Ok. I did it as mecool km9. I will change it with xiaomi.
        I changed it as xiaomi mi mix 3 android 9 and still same. No safety net.
        any advice pls
          any advice pls
          Then you must emulate all 7 or more properties of that device too.
            All 7? Sorry I dont understand.
            could you pls explain more specific. Or can you give me which fingerprint should I choose.
            thnks
              thnks
              Any Android 9 fingerprint.
              Then you must manually also emulate all 7 properties like device, manufacturer, model etc under 'Improved hiding (disabled)'.
              Choose not to restart after each one and only restart after you emulated all the properties.
              Couldn't be easier.
                Hitachi , mo123 ,
                Maybe you should continue your dialogue in personal correspondence?
                • mo123
                  mo123 commented
                  Editing a comment
                  I think it's a good idea. The user can contact me if he needs more help since there are too many posts now that aren't related to your firmware.
                #98
                Wonder if this from would work on the new AM6 PLUS box with 922xj cpu?
                  Suitable for AM6, AM6 Pro and AM6 PLUS.
                    Originally posted by Sasvlad View Post
                    mo123 ,
                    Maybe you should continue your dialogue in personal corr... ?
                    I personally think mo123 should open a thread pertaining and dedicated to ALL A9.0/Chipsets, he is skilled in the art of 'tweak'.
                    IT would benefit All concerned & iinterested owners of 905x3 & 922x devices... I'll bet!
                    Thanks for Both of you Gentlemen!, smiles!
                      Sasvlad, ist die AM6 Plus already out ?
                        Yes. (oder Ja )
                          Yes. (oder Ja )
                          thanks. where to buy in europe ?
                            https://ugoos.com/ugoos-am6-plus-s922xj-tvbox-android9
                            Glauben Sie wirklich, dass es solche Prozessoren gibt? Dies ist nur eine Software-Shell.
                              die gibt es jetzt auch von Minix. Ist also eine neue Prozessorrevision mit besserer Dolby Unterstützung
