T-R42 custom firmware by wasser
    version 1.2.2
    - all feature from 1.2.1
    - updated kernel, improved suspend/resume, stability
    - fixed key mapping issue
    Link download:
    t-r42-wasser-1.2.2.zip
    version 1.2.1
    - added several parameter files
    - added boot-1080p and 720p images
    - added Wifi Display app
    Be aware: it is your own risk!
    Link download:
    t-r42-wasser-1.2.1.zip
    version 1.2
    - bluetooth support
    - wifi support
    - ethernet support
    - init.d support
    - 1080p24hz, 1080p30hz support
    - frame skipping fix for video play
    - rooted
    - ntfs, nfs, iso filesystem support
    - 40% like performance boost
    - preinstalled ouya xbmc with passthrouh support
    Link download:
    fix issue with stock ir remote, please use cwm recovery to flash the fix
    it would be nice of someone could post some feedbacks to the rom
    thanks
      thanks
      I think it would be better in the K-R42 / CS918 / MK888 / Jesurun DX05 section. That's where all the other T-R42 posts are and I don't think that many people look here lol.
      Did you say in the K-R42 thread that this will work on the K-R42 also? If so do we need to flash a different kernel after the rom or is the kernel compatible with both ?
      To Infinity and Beyond.... XBMC
        this firmware is made for t-r42. It won't work on k-r42. Only cwm recovery which is included in this firmware, works both t-r42 and k-r42
          Ah, ok mate. No problem, I will wait for a k-r42 rom to try.
            thanks
            Thanks for the ROM, wasser. I've just installed and immediately ran into an issue with wireless; as soon as I enable it the system crashes. It turns off completely and crashes trying to boot. I've had to perform a factory reset to get the device booting again.
            I'll report back with any further issues I may encounter.
              thanks
              The ROM looks great thanks for your hard work as soon as my device arrives i will load your rom and give you my feedback you should post links to this thread on Geekbuying
              My Device: T-R42
              ROM: Wasser ?????
              Peripherals: 5Port USB-2 Hub : Logitech K700 Keyboard : Buffalo 1TB HDD : 32 GB MicroSD : Wireless Xbox360 Controller : 5amp switch mode power supply
                Hi wasser i flashed your kernels but i have a problem WiFi is not working I don`t know why
                Please help
                Edit: Ethernet is not working also
                  Please help
                  which hardware do you have? the firmware only works in t-r42. could you please post the dmesg log after you enable wifi in the settings?
                  To get the dmesg log you need to install terminal app and just do: su - && dmesg > dmesg.log
                  thanks
                    which hardware do you have? as i notived it only works on t-r42. some users have flash the firmware and wifi/ethernet work out the box
                      thanks
                      Hi wasser i downloaded get logs apk and hers the file i hope you have everything you need here.If you need something else PM me. data.txt
                        Hi wasser i downloaded get logs apk and hers the file i hope you have everything you need here.If you need something else PM me. [ATTACH]3563[/ATTACH]
                        your log file does not include the dmes log what i need to debug. the build.prop included in your log file looks like from K-R42_HFW firmware! Please tell which hardware you have and which firmware you have flashed?
                        it looks like you have flashed the wrong firmware!
                        thanks
                          I'm running a T-R42. Would you like me to supply dmesg?
                            thanks
                            Hi wasser i have the T-R42 box,and i flashed K-R42_HFW and I flashed this kernel :http://d-h.st/Wn1
                            With this kernel everything should work with the HWF firmware and the T-R42 box right?
                            Anyways I`l flash your firmware and report my findings.
                              http://pastebin.com/cVxbty7A
                              Here's my dmesg output (link in title of post).
                              PS: I am not able to provide the output after enabling WiFi, as the device crashes immediately. It will then refuse to boot until a factory reset is performed in CWM recovery.
