T-R42 custom firmware by wasser
Dmesg File attached
Wasser
I attached dmesg.txt
Michael T.
Originally posted by wasser View Postcould you please make a dmesg log in this case?
thanks3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
CVSB-K200-Wireless Mini QWERTY Keyboard / Motion Mouse for Android RF
Rii Mini i25 Qwerty Keyboard/Motion Mouse For Android RF
Media Flow Suite ... 24 TB ReadyNas Pro wired 1 GB Ethernet
Hello Wasser
Hello Wasser,
I have been testing Your K-R42 Kernels ... Very Nice ...
Two Small things:
1) It Would be Nice to Have the LED Button Turn Orange when in sleep Mode.
(Not Very important just nice)
2) If I reboot From The Power Button Menu then the System starts having USB issues
with Remote sleep and USB devices not waking up ...
NOTE: This issue ONLY happens if I reboot using the Power Button Menu .
Normal Power on works great and no issues ...
3) I still have to test stay awake over night will Report in morning ...as to status ...
Thanks for the great work ...
Michael T.
Originally posted by wasser View Postit's exactly what i'm trying to fix the kernel to behave like the stock kernel , but it's not easy. it takes time!3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
i uploaded new 1080p-kernel for t-r42. Could you please test wifi/ethernet/bluetooth and wakeup from suspend/sleep?
please reports and attach the dmesg log
thanks
Originally posted by wasser View Posti uploaded new 1080p-kernel for t-r42. Could you please test wifi/ethernet/bluetooth and wakeup from suspend/sleep?please reports and attach the dmesg log http://d-h.st/CeQ thanks.
Originally posted by michael2t View PostHello Wasser,I have been testing Your K-R42 Kernels ... Very Nice ... Two Small things:1) It Would be Nice to Have the LED Button Turn Orange when in sleep Mode. (Not Very important just nice) 2) If I reboot From The Power Button Menu then the System starts having USB issues with Remote sleep and USB devices not waking up ... NOTE: This issue ONLY happens if I reboot using the Power Button Menu . Normal Power on works great and no issues ...3) I still have to test stay awake over night will Report in morning ...as to status ... Thanks for the great work ... Michael T.
2. it looks like a bug in the firmware, but not in kernel
Hi all,
I joined this forum a few days ago due to problems encountered with my T-R42 box. Actually, I am planing on selling it because its actually of no use right now. It really doesn't matter what Player I use, 1080p videos are un watchable. 720p videos are also not very smooth - XBMC is even the worst of all. I have tried different XBMC builds without luck.
Can someone here confirm if a smooth 1080p video playback is possible on this unit? if the answer is yes, what player would you recommend?
I used to have Minix Neo X5 for almost 11 months. They also promised 1080p but after 11 months they still could not get it to play well. I was sick and tired of the unit so I sold it and now I am stuck with this one and once again not able to deliver the 1080p as promised even with quad core.
It would also be nice if someone can direct me to a good guide on how to flash firmwares and how to root this unit (A-TR42). I would also like to know the difference between firmwares and kernels and when to flash what.
I will very much appreciate your help.
Tested 1.2 and the updated kernel - here are my observations
First, great work on the ROM. I did a bit of testing and things are working fairly well. There is one issue and one addition:
- In all the kernel's that I've used, there is a boot1080p that is required to set the high resolution. Your kernel has 1080p support, but there is no boot to correspond. (reference Finless Bob's ROMs). In testing, I found that even though you can set 1920x1080p, you are only actually getting 1280x720p. Setting the higher resolution actually appears clearer, but does not add resolution.
Any chance of a boot1080p or am I missing something?
- On addition I made was to use the 6gb parameter file from Finless. My T-R42 8gb Flash, and the additional space is helpful.
Antutu Benchmark was quite good; 18800. Video Playback was also smooth. I ripped 1080p mkvs from a couple of Blueray disks and they look fine and smooth. Ethernet, Wifi, and bluetooth also work as expected. I've noticed a few strange reactions to Ethernet versus Wifi. If you use ethernet, the tray often says 'no internet connection'. Seems like it shouldn't care ethernet versus wifi. Any thoughts here or is that just the Android?
Thanks again!
I've tried the rom from .06 to 1.2,
all work fine!
but roms are not stable, make the device auto shutdown by itself after a few hours. Does anyone have the same problem?
Originally posted by wasser View Postversion 1.2
- bluetooth support
- wifi support
- ethernet support
- init.d support
- 1080p24hz, 1080p30hz support
- frame skipping fix for video play
- rooted
- ntfs, nfs, iso filesystem support
- 40% like performance boost
- preinstalled ouya xbmc with passthrouh support
Be aware: it is your own risk!
Link download:
fix issue with stock ir remote, please use cwm recovery to flash the fix
http://androidtv.b42.nl/wasser/t-r42-ir-remote-fix.zip
Originally posted by kakoi View PostI've tried the rom from .06 to 1.2,all work fine!but roms are not stable, make the device auto shutdown by itself after a few hours. Does anyone have the same problem?
Originally posted by sarcher3 View PostHi Wasser - First, great work on the ROM. I did a bit of testing and things are working fairly well. There is one issue and one addition:- In all the kernel's that I've used, there is a boot1080p that is required to set the high resolution. Your kernel has 1080p support, but there is no boot to correspond. (reference Finless Bob's ROMs). In testing, I found that even though you can set 1920x1080p, you are only actually getting 1280x720p. Setting the higher resolution actually appears clearer, but does not add resolution. Any chance of a boot1080p or am I missing something? - On addition I made was to use the 6gb parameter file from Finless. My T-R42 8gb Flash, and the additional space is helpful.Antutu Benchmark was quite good; 18800. Video Playback was also smooth. I ripped 1080p mkvs from a couple of Blueray disks and they look fine and smooth. Ethernet, Wifi, and bluetooth also work as expected. I've noticed a few strange reactions to Ethernet versus Wifi. If you use ethernet, the tray often says 'no internet connection'. Seems like it shouldn't care ethernet versus wifi. Any thoughts here or is that just the Android?Thanks again!
2. several parameter files will be added in next firmware
3. that the tray says "no internet connection" is new for me. it should not. Could you please attach the screenshot from the tray with "'no internet connection"?
thanks
- follow the instructions from here
testing 1080p kernel 10-30-2013 build
Hello Wasser,
10-30-2013 kernel test 1080p ...
I tested the NEW kernel ...
1) It still stops working after 3-5 sleep on/off
2) It is different ... Because Now the Power Button on the Unit will wake it
Back up (sometimes it works...but not always) ... before I had to unplug it ...
I have attached dmesg.txt
Michael T.
Originally posted by wasser View Post3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
Tested K-R42 Stay awake overnight
Hello Wasser,
Two Small things:
NOTE: The Unit correctly stays awake over night ... Now
10-31-2013
Michael T.3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
Michael T.
[ATTACH]3737[/ATTACH]
the dmesg looks fine to me, it's strange that it doesn't work correctly.
Does the issue behave like in k-r42?
"If I reboot From The Power Button Menu then the System starts having USB issues
Normal Power on works great and no issues"
thanks
There are currently 2519 users online. 1 members and 2518 guests.
