thanks
T-R42 custom firmware by wasser
Hello Wasser
Hello Wasser,
I am Sorry ... I have to be a the hospital ... my Mother had a heart attack ...
I will have to work with you on Monday ...
But ... Thank You for the Kind words ...
But I have to go now ...
Thanks again for the Firmware and hard work ...
Michael T.
Originally posted by wasser View Postyes, it's almost done for t-r42. I need some good testers to test it before i want to release official. You are my favorit-tester ;-)
thanks3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
CVSB-K200-Wireless Mini QWERTY Keyboard / Motion Mouse for Android RF
Rii Mini i25 Qwerty Keyboard/Motion Mouse For Android RF
Media Flow Suite ... 24 TB ReadyNas Pro wired 1 GB Ethernet
Michael T.
Did anyone try this ROM on a B351_BT (also an t-r42 clone I think)?
I'm not sure if I should try.
How can I dump the partitions ?
I tried romdump, but get errors on kernel and boot (only have system dump).
Does dd or cat work or will it corrupt the partition.
Thanks !
Here is what Android Dump gave me:
Code:[COLOR=#222222][FONT=arial]..:: System Info[/FONT][/COLOR][COLOR=#222222][FONT=arial]Available Memory (Mb)=1488 Total Memory (Mb)=1874 ANDROID_ID=bcc42bb7c6fcefdd CURRENT_TIME_MILLIS=1384620943904 TIME-STAMP=Sat Nov 16 17:55:43 MEZ 2013 LOCALE=de_DE ANDROID_SOCKET_zygote=14 RK_ADEPT_DEVICE_SALT_FILE=/mnt/sdcard/.adobe-digital-editions/devicesalt RK_ADOBE_DE_MOBILE=1 ANDROID_BOOTLOGO=1 EXTERNAL_STORAGE=/mnt/sdcard ASEC_MOUNTPOINT=/mnt/asec RK_ADEPT_DEVICE_FILE=/mnt/sdcard/.adobe-digital-editions/device.xml RK_ADEPT_DEVICE_TYPE=mobile BOOTCLASSPATH=/system/framework/core.jar:/system/framework/core-junit.jar:/system/framework/bouncycastle.jar:/system/framework/ext.jar:/system/framework/framework.jar:/system/framework/telephony-common.jar:/system/framework/mms-common.jar:/system/framework/android.policy.jar:/system/framework/services.jar:/system/framework/apache-xml.jar EXTERNAL_STORAGE_USE_DATA=/storage/sdcard0 SECOND_VOLUME_STORAGE=/mnt/external_sd HOST_STORAGE_DIRECTORY_EXTERN_3=/mnt/usb_storage/USB_DISK3 HOST_STORAGE_DIRECTORY_EXTERN_2=/mnt/usb_storage/USB_DISK2 HOST_STORAGE_DIRECTORY_EXTERN_5=/mnt/usb_storage/USB_DISK5 HOST_STORAGE_DIRECTORY_EXTERN_4=/mnt/usb_storage/USB_DISK4 EBOOK_PAGE_VISIBLE_NUMBER=2 ANDROID_DATA=/data ANDROID_ROOT=/system LD_LIBRARY_PATH=/vendor/lib:/system/lib RK_ADEPT_ACTIVATION_FILE=/mnt/sdcard/.adobe-digital-editions/activation.xml ANDROID_STORAGE=/storage ADOBE_FONTS_DIR=/system/fonts/adobefonts/ HOST_STORAGE_DIRECTORY_EXTERN_0=/mnt/usb_storage/USB_DISK0 ANDROID_ASSETS=/system/app HOST_STORAGE_DIRECTORY_EXTERN_1=/mnt/usb_storage/USB_DISK1 PATH=/sbin:/vendor/bin:/system/sbin:/system/bin:/system/xbin LOOP_MOUNTPOINT=/mnt/obb RK_ADOBE_DE_DOC_FOLDER=/mnt/sdcard/Digital Editions THIRD_VOLUME_STORAGE=/mnt/usb_storage/USB_DISK0 ANDROID_PROPERTY_WORKSPACE=13,32768[/FONT][/COLOR] [COLOR=#222222][FONT=arial]..:: Version Info CodeName=REL Incremental=eng.linking.20130923.145135 Release=4.2.2 SDK=17 SDK-Version=17[/FONT][/COLOR] [COLOR=#222222][FONT=arial]..:: Build Info Board=rk31sdk Brand=rk31sdk CPU ABI=armeabi-v7a Device=rk31sdk Display=rk31sdk-eng 4.2.2 JDQ39 eng.linking.20130927.145135 test-keys Fingerprint=rk31sdk/rk31sdk/rk31sdk:4.2.2/JDQ39/eng.linking.20130923.145135:eng/test-keys Host=localhost ID=JDQ39 Manufacturer=rockchip Model=rk31sdk Product=rk31sdk Tags=test-keys Time=1379919125000 Type=eng User=root[/FONT][/COLOR] [COLOR=#222222][FONT=arial]..:: Screen Info DisplayId=0 Resolution=1280x672 Orientation=1 RefreshRate (fps)=60.000004 Density Dpi=160 Density=1.0 Scaled density=1.0 Xdpi=160.42105 Ydpi=160.15764[/FONT][/COLOR] [COLOR=#222222][FONT=arial]..:: DateTime Info Locale= de_DE Locale Country= DE Locale Language= Deutsch Locale Variant= Locale ISO Country= DEU[/FONT][/COLOR] [COLOR=#222222][FONT=arial]..:: TimeZone TimeZone Name= Mitteleuropäische Zeit TimeZone DST Saving= 3600000 TimeZone Row offset= 3600000 TimeZone SHORT= 0[/FONT][/COLOR] [COLOR=#222222][FONT=arial]..:: Secure Info INSTALL_NON_MARKET_APPS=1 LOCATION_PROVIDERS_ALLOWED=gps DEVICE_PROVISIONED=1 ANDROID_ID=bcc42bb7c6fcefdd WIFI_WATCHDOG_ON=1 ADB_ENABLED=1 USB_MASS_STORAGE_ENABLED=1 WIFI_NETWORKS_AVAILABLE_NOTIFICATION_ON=1 BLUETOOTH_ON=0 WIFI_ON=0 DATA_ROAMING=1 [/FONT][/COLOR] [COLOR=#222222][FONT=arial]..:: File build.prop # begin build properties # autogenerated by buildinfo.sh [URL="http://ro.build.id/"]ro.build.id[/URL]=JDQ39 [URL="http://ro.build.display.id/"]ro.build.display.id[/URL]=rk31sdk-eng 4.2.2 JDQ39 eng.linking.20130927.145135 test-keys ro.build.version.incremental=eng.linking.20130923.145135 ro.build.version.sdk=17 ro.build.version.codename=REL ro.build.version.release=4.2.2 ro.build.date=Mon Sep 23 14:52:05 CST 2013 ro.build.date.utc=1379919125 ro.build.type=eng ro.build.user=root ro.build.host=localhost ro.build.tags=test-keys ro.product.model=rk31sdk ro.product.brand=rk31sdk [URL="http://ro.product.name/"]ro.product.name[/URL]=rk31sdk ro.product.device=rk31sdk ro.product.board=rk31sdk ro.product.cpu.abi=armeabi-v7a ro.product.cpu.abi2=armeabi ro.product.manufacturer=rockchip ro.product.locale.language=en ro.product.locale.region=US ro.wifi.channels= ro.board.platform=rk30xx # ro.build.product is obsolete; use ro.product.device ro.build.product=rk31sdk # Do not try to parse ro.build.description or .fingerprint ro.build.description=rk31sdk-eng 4.2.2 JDQ39 eng.linking.20130923.145135 test-keys ro.build.fingerprint=rk31sdk/rk31sdk/rk31sdk:4.2.2/JDQ39/eng.linking.20130923.145135:eng/test-keys ro.build.characteristics=tablet # end build properties # # system.prop #[/FONT][/COLOR] [COLOR=#222222][FONT=arial]#rild.libpath=/system/lib/libreference-ril.so #rild.libargs=-d /dev/ttyUSB2 # Default ecclist ro.ril.ecclist=112,911 # zpl, set to yes for board have power button on board. and it will also display 3 options in power menu (POWEROFF/STANDBY/REBOOT) ro.board.powerkey=no # zpl, some extra information of firmware [URL="http://ro.customer.name/"]ro.customer.name[/URL]=sztena ro.board.model=BX09 ro.build.date.ymd=NOTSET[/FONT][/COLOR] [COLOR=#222222][FONT=arial]# # ADDITIONAL_BUILD_PROPERTIES # ro.com.android.dateformat=MM-dd-yyyy ro.config.ringtone=Ring_Synth_04.ogg ro.config.notification_sound=pixiedust.ogg ro.carrier=unknown ro.config.alarm_alert=Alarm_Classic.ogg dalvik.vm.heapstartsize=8m dalvik.vm.heapgrowthlimit=80m dalvik.vm.heapsize=384m dalvik.vm.heaptargetutilization=0.75 dalvik.vm.heapminfree=512k dalvik.vm.heapmaxfree=8m ro.sf.lcdc_composer=0 keyguard.no_require_sim=true ro.com.android.dataroaming=true ril.function.dataonly=0 persist.sys.usb.config=mtp persist.sys.strictmode.visual=false dalvik.vm.jniopts=warnonly ro.rksdk.version=RK30_ANDROID4.2.2-SDK-v1.00.00 sys.hwc.compose_policy=6 sys.ffmpeg_sf.switch=0 sys.dts_ac3.shield=0 sf.power.control=2073600 ro.sf.fakerotation=true ro.sf.hwrotation=270 ro.rk.MassStorage=false ro.rk.systembar.voiceicon=false wifi.interface=wlan0 ro.tether.denied=false ro.sf.lcd_density=160 ro.rk.screenoff_time=-1 ro.rk.def_brightness=200 ro.rk.homepage_base=[URL="http://www.google.com/webhp?client=%7BCID%7D&source=android-home"]http://www.google.com/webhp?client={CID}&source=android-home[/URL] ro.rk.install_non_market_apps=false ro.default.size=100 persist.sys.timezone=Atlantic/Azores ro.product.usbfactory=rockchip_usb wifi.supplicant_scan_interval=15 ro.opengles.version=131072 ro.factory.tool=0 ro.kernel.android.checkjni=0 ro.rk.bt_enable=true ro.factory.storage_policy=0 testing.mediascanner.skiplist=/mnt/sdcard/Android/ video.use.overlay=0 ro.vendor.sw.version=RK3188_R-BOX_ANDROID4.2.2-SDK_V1.0.0_130514 ro.product.version=RK3188_BOX_SZTENA_BX09_NEUTRAL_8188EU_20130625 ro.product.ota.host=[URL="http://sztena.otaupgrade.com:2300/"]sztena.otaupgrade.com:2300[/URL] dalvik.vm.dexopt-flags=m=y [URL="http://net.bt.name/"]net.bt.name[/URL]=Android [/FONT][/COLOR] [COLOR=#222222][FONT=arial]dalvik.vm.stack-trace-file=/[/FONT][/COLOR][COLOR=#222222][FONT=arial]data/anr/traces.txt[/FONT][/COLOR]
i uploaded the 1.2.2 firmware, it would be great if someone please test it and post the results!
sadly i don't have hardware to test
thanks
t-r42-wasser-1.2.2.zip
Originally posted by wasser View Posti uploaded the 1.2.2 firmware, it would be great if someone please test it and post the results!
thanks
Just test your firmware.
it is only 720p.
Wifi is disabled by default. if turn it on. Device going to circle reboot. Only Wipe user data from recovery helps. Standby-resume Works fine.
Switch back to 1.2.1. Wifi works fine. 1080p. But resume works only few second after standby. If wait litle bit more device can be swinched on only by pressing button on device.
Thank you for your efforts.
Is there no problem on the link?
Can not download the file.
Thanks,
thanks
it is only 720p.
- please download the 1.2.2 firmware and flash again. There's a regression in 1.2.2 from yesterday. Wifi works again in new 1.2.2 from today
thanks
Hi Wasser,
Suspend/Resume now worked great! You nailed this stubborn one. It worked like the Stock Firmware with LED light indicator.
AnTuTu score of 19000+.
Thanks for your hard work. Love your firmware and it is perfect for my T-R42 box.
Only two minor issues left for me:
1) Issue with backup through CWM. It never completed and always stuck at backing up the last one which is the data one(All Versions 1.1 and 1.2). Progress bar indicates about 10% done then stuck with no response.
2) NFS mounting not working. I tried to mount through Terminal and mount commands executed fine with no error messages returned but getting a circle spinning forever and no contents showed up when navigating to mounted share folders through ES File Explorer. My work around ATM is using XBMC to mount all the NFS shares for all my streaming needs and it worked great and CIFS for Android local accessing/editing needs.
BTW, I noticed you added the new video overlay feature. Can't wait to test it out.
Thanks.Last edited by xatang2013; 17 November 2013, 23:38.
Originally posted by wasser View Post- it's real 1080p kernel. The new kernel uses now video overlay which has great video performance. It uses 720p for GUI and real 1080p for video playback.
Same problem. Enabling WIFI or WIFI hotspot lead to circle reboot. only wipe system data helps. By the way, CWM recovery provided in you ROM can not mount external_SD. I took another CWM and it works.
Originally posted by bluesoho View PostThanks wasser,
Can I handle SDcard unmount?
When I update 1.2.2 firmware, the SDcard is unmounted.
Sent from my SHV-E250S using Tapatalk
Here are the Complete steps to mount Nand Flash SD:
If your Nand Flash not mounted then do these steps:
1) Go to /Settings/Storage/Nand Flash
2) Do mount Nand Flash if it not currently mounted.
3) If you get "Blank Internal Flash" message down in the status bar then click on it from the status bar. You will get a message that it needs to be formatted before use then just go ahead and format it.(NOTE:FORMAT MESSAGE HIDES you MUST Select Message on status bar to See Format request.
4) Exit out of Settings after it formatted.
5) Go back to Settings again and you should now see Nand Flash SD is mounted.
There are currently 1316 users online. 4 members and 1312 guests.
