T-R42 custom firmware by wasser
Wasser
Hello Wasser,
I tested the new kernel on the 1.2.1 and all works fine ...
Both Wifi and blue tooth work fine ...
Michael T.3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
CVSB-K200-Wireless Mini QWERTY Keyboard / Motion Mouse for Android RF
Rii Mini i25 Qwerty Keyboard/Motion Mouse For Android RF
Media Flow Suite ... 24 TB ReadyNas Pro wired 1 GB Ethernet
First time poster here. I have been following this thread. I flashed the 1.2.1 and I like it. I first used the boot-1080p and kernel-1080p files a thought it looked a little too large. I then flashed with boot-720p and kernel-720p and it looked much smaller. Are the file names reversed maybe? Also, I tested out the 1.2.2. and I also had the wifi and bluetooth problems. I tested the 1.2.2 kernel with the remaining 1.2.1 files and wifi and bluetooth both work. One thing i noticed is when you try and remove icons from the home screen, the word "remove" is missing from the top of the screen. The removal still works though.
Michael T.
thanks
Wasser
Hello Wasser,
That did it ... Bluetooth and Wifi now working ...
Good Work ...
Michael T.
Originally posted by wasser View Posti even pm you an zip file. Could you please test if bluetooth works again?
thanks3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
Good Work ...
Michael T.
could you please test wifi, ethernet, bluetooth, video if all are running stable before i want to release 1.2.3
thanks for your excellent testing/reports !
Wasser
Hello Wasser,
I tested Ethernet, Blue-tooth and WIFI ... all work fine
But I have to go Visit My mother in the hospital ... I will test the video in the morning ...
Maybe Bill-ns can test the video ...
Have a good evening all
Thanks again Wasser for all of your hard work ...
Originally posted by wasser View Posti will upload the new 1.2.3 at this weekend. xbmc with passtrough support will be added in 1.2.3.
Have you had chance to look at CWM and fix the backup issue yet? I been holding off loading any new firmware you uploaded since I didn't have a solid backup.
I am currently running your older 1.2.1 version with the new kernel where Sleep/Resume fixed and new video overlay feature added. Everything running good for me with this combo.
1080p playback is huge difference now. My TV keep popping up 1080p resolution when playing 1080p files. The resolution is great and it must be real 1080p.
Thanks.
Originally posted by wasser View PostIt's strange! i need more infos
1 Which firmware did you flash ?
2 please post dmesg log and lsmod
3 please post the output of "cat /proc/filesystems"
thanks
Just flashed your FW 1.2.2 to my B351_BT. The ROM boots up, but it sometimes shuts down (especially when I connect and use my MELE F10 air mouse & keyboard edit: also with other input methods) and when I try to activate WiFi (AP6210) it reboots and I gets stuck in a bootloop
edit: I also flashed your kernel from here, but it didn''t help
I flashed back the stock t-r42 firmware from Geekbuying and everything works again.
I took 2 photos of my board.
Could you help me with this ?
Let me know which information you need.
I would be very happy to get this working, as the ROM feels very smooth !!
Thanks !!
Originally posted by d1dd1 View PostJust flashed your FW 1.2.2 to my B351_BT. The ROM boots up, but it sometimes shuts down (especially when I connect and use my MELE F10 air mouse & keyboard edit: also with other input methods) and when I try to activate WiFi (AP6210) it reboots and I gets stuck in a bootloop
There are currently 2735 users online. 0 members and 2735 guests.
