Hello Wasser,
Report ON T-R42
My Results from My Testing:
A) Flashed All images and loader and Parameter file.
B) Tried to Test Parameter file 8 and 10 ... But System Would Error
During Flash with Parameter8 or parameter10 only parameter file works correctly
C) I erasedIDB before Flashing and Still Have to Manually Mount and Format Nand
Then Reboot Into CWM and Mount SDcard
1) Tested Wifi ... if Selected System Will Endless Loop Rebooting
I had to reflash for the System to get normal Boot again.
2) Tested Bluetooth and Would NOT turn on (Worked Fine with Previous version both Wifi and Bluetooth)
3) Power (Sleep) on / off with out any USB works great Tested 30 On / Offs
4) Power (Sleep) on / off with USB Hard Drive works Great Tested 30 On / Offs
5) Ethernet Working Fine ...
6) Video Plays Fine ...
7) Reflash to Get Player To Work again ... After selecting Wifi
System Never Completely Boot so there was No way to get dmesg
as Player NEVER boots Far enough to get connected ...
Good Work I really Like the New Sleep Mode Still More Network Testing to Do ..
I will Report my findings ... Once I have Done a Complete Network Test ...
Michael T.
