T-R42 custom firmware by wasser
Originally posted by q20 View Post
It's working fine.
I don't remember, but in the Settings - Memory (or Programs ?) you'll see a "NAND Flash" under the memory usage screen graph. Click on this to initialize the NAND memory. After this, the sdcard will be available.
Originally posted by snickers View PostI would be willing to help test overclocked kernels. I could always use some extra performance
The root case is overheating, I think.
Make sure heatsinks are installed on the chips.
Originally posted by DenH8k View PostBe carefull, I saw one users' report from another forum about the crashing of Memory controller chip after this operation.
Settings - (Device) Memory, scroll down under the memory utilization diagrams, and click on the "Mount NAND Flash" menu.
BTW. Did someone try compare the efficiency of some media pleer like Iconbit HDS41L powered by Realtek RTD1073 and our device when they play video? I become to hesitate that i sold my player for nothing. T-R42 play 20Gb video as not so smoothly as HDS41L.
Hi Wasser
Would you be able to update your first post with a link to your 1.2.1 firmware? By now, it's buried in this thread.
A couple nights ago I installed the latest geekbuying firmware, but didn't really notice any differences between it and the original, so I'm back to your 1.2.1. Much better.
I've noticed some issues with my C270 camera when using the latest Skype .apk. Not sure at this point if that's a problem with Skype or something else. The camera seems to work until the call is being connected. Then Skype crashes out. I see recommendations of using a powered hub. I'll have to see if I can try that.
On a previous 1.2.1 install I installed the latest justxbmc.apk and noticed some jittery video during some streaming from the USTVNow addon. I haven't tested enough to know if it happens elsewhere.
Hope to have some more testing time in the next few days...
Thanks!
Bill
Couple more things...
Camera (for the C270) support seems to be unstable. Sometimes it works with the Camera app, sometimes it requires the camera to be unplugged and plugged back in for it to start working.
Skype video remains unusable. Calls are dropped when the camera starts to come online.
When the box is booted, if there's a USB drive plugged in, I was having problems with the NAND not being mountable. I'd try to mount it, but no go. Would only work after I unplugged the USB drive. Then during a reboot it mounted properly.
Netflix audio is off just a bit... not nearly as bad as xbmc audio (which is able to be solved using an offset value). It's manageable. Not using a receiver... just HDMI straight to the TV for A/V.
Bill
edit..
One more thing. When "Sleep" is pressed from the task bar, the device briefly goes to sleep, the button turns red for about 10 sec, then turns completely off. When the button is repressed, it starts up cold. Not really a big deal either... I don't use sleep... the box doesn't make any heat and seems to be happy running 24/7.
Thanks!
Bill
- please use the skype3.2, the latest skype doesn't work
Hello Wasser
Hello Wasser,
Thanks for all of Your Hard work ...
>Are You going to release 1.2.2 for the t-r42 also ???
Just answered .... Great
thanks
Michael T.3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
CVSB-K200-Wireless Mini QWERTY Keyboard / Motion Mouse for Android RF
Rii Mini i25 Qwerty Keyboard/Motion Mouse For Android RF
Media Flow Suite ... 24 TB ReadyNas Pro wired 1 GB Ethernet
There are currently 2020 users online. 0 members and 2020 guests.
