T-R42 custom firmware by wasser
    Originally posted by d1dd1 View Post
    Just flashed your FW 1.2.2 to my B351_BT. The ROM boots up, but it sometimes shuts down (especially when I connect and use my MELE F10 air mouse & keyboard edit: also with other input methods) and when I try to activate WiFi (AP6210) it reboots and I gets stuck in a bootloop
    edit: I also flashed your kernel from here, but it didn''t help
    I flashed back the stock t-r42 firmware from Geekbuying and everything works again.
    I took 2 photos of my board.
    Could you help me with this ?
    Let me know which information you need.
    I would be very happy to get this working, as the ROM feels very smooth !!
    Thanks !!
    I have absolutely the same device and problem as you described. And performing Erase IDB before flashing don't help.
      There is an issue with 1.2.2. It will boot, but when you switch on WiFi it bootloops. 1.2.1 will work however, although not perfect (it has little stability issues, and sleep/resume does not work), but I'm very happy with it. It beats the stock firmware hands down. Or you can wait till Wasser brings out version 1.2.3 which might be this weekend, and flash that.
        I flashed the 1.2.1 and WiFi works there. Thanks !
        Both (1.2.1 & 1.2.2) have heavy stability issues with my device (sudden reboots or shutdowns or app closes).
        None of them are noticable in the T-R42 ROM from Geekbuying
          Here is the output of "cat /proc/last_kmsg" if this helps in any ways. It contains the log before the last crash.
          I think the /sdcard behaves strange, sometimes it is mounted, sometimes not and sometimes I can't mount it in storage settings
          last_ksmg.txt
            Hello D1dd1
            Hello D1dd1,
            Sorry Just popped in,
            If You can NOT Mount NAND ... the fix is easy ...
            Reboot to CWM wipe with both options on first page then Go to advanced and wipe there to ...
            Then Reboot and Mount NAND option and Watch for Format in corner .. after formatting
            Reboot to cwm and go to mount and mount sdcard
            then reboot and all will be fine ...
            Good Luck
            Michael T.
            3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
            CVSB-K200-Wireless Mini QWERTY Keyboard / Motion Mouse for Android RF
            Rii Mini i25 Qwerty Keyboard/Motion Mouse For Android RF
            Media Flow Suite ... 24 TB ReadyNas Pro wired 1 GB Ethernet
              Testing Report
              Hello Wasser,
              Please NOTE: All testing is done with the Same USB Air Mouse/Keyboard
              ,USB Hard drive and Optical Remote (stock) from Geek-Buying... , All Hooked up to the
              Players through a Powered 10 port USB hub ...
              Bug Report for 1.2.2 Firmware on T-R42 and K-R42.
              USB Hard drive ... about 80% of the time I start the Player K-R42
              and have My USB Hard drive Hooked Up and A Notification is added to
              the Notification bar stating Preparing USB Drive but it never Mounts it.
              If I click on it ... Then it start the Mounting and I can Access the USB Hard drive ...
              I just completed my testing on the T-R42 ...and It boots the USB Hard drive Ever Time
              with out issue ... I powered on/off 20 Times ... It work every time ... Flawless
              K-R42 ----.
              Strange, When I shut down the Player Using the Optical Remote I hold the POWER button and Select Power Off ... It takes a long time ...
              Which is OK... Then On the Notification bar I get a Message Blank Internal Flash ...
              Like something is NOT Right ... The The Power shuts off ... correctly.
              I have test this on the T-R42 ... and it does NOT Power off at all it always
              Reboots ... If I Select Reboot it Reboots if I select Power Off it Reboots ...
              If I select Sleep it sleeps ...
              On the T-R42 the SDCARD is NOT showing Mounted ...
              Is Shows Calculating and NEVER Returns any Values
              On The K-R42 the SDCARD is showing NOT mounted no Matter
              What I set ...
              I can View the internal SDCARD folder and read/write them so something
              Else MUST BE wrong in the settings Function as the internal sdcard is working fine...
              Just NOT showing up correctly on the Settings page ...
              There Is some kind of Bug on The K-R42 1.2.2 Firmware as When on the HOME screen If I want to Remove a Icon I click on it and the Frame shows but the Remove X Phase that show at the top of the screen on
              The T-R42 does NOT show Up on the K-R42 ....
              I have attached to screens Shows Showing the SDCARDs not showing
              up correctly in the Setting Page ...
              On both the T-R42 and K-R42 I can Mount the sdcard in the CWM ...
              The Display Issues are all in the Settings page ... As I can Read and write to the sdcard
              folders on both the T-R42 and the K-R42... As You can See by the screen shots I save to the internal sdcard ...
              Thanks again for all the hard work ...
              I am Looking forward to the 1.2.3 versions ...
              Michael T.
                1.2.1 is the best for now you only need to format internal storage on first boot and the problem seems ok after that but video playback is frame skipping ether streaming or from storage so looking forward to new version 1.2.3
                @Michael2t you have in your sig that you are running k-42 firmware on t-42 what kernel did you use ? is everything working with that rom
                My Device: T-R42
                ROM: Wasser ?????
                Peripherals: 5Port USB-2 Hub : Logitech K700 Keyboard : Buffalo 1TB HDD : 32 GB MicroSD : Wireless Xbox360 Controller : 5amp switch mode power supply
                  Hello WapVirus
                  Hello WapVirus,
                  I am Running 1.2.2 for My T-R42 And 1.2.2 For My K-R42 Player both By Wasser and
                  Both With Wasser complete firmware ... nothing else ...
                  I have a updated Alpha Version of the T-R42 1.2.3 with special updates, I am Testing with Wasser
                  that will release with the update over the weekend in 1.2.3 for the T-R42 ...
                  I am using the 1.2.2 Posted Version for Old on my K-R42 ...
                  On My T-R42 My blue-tooth and Wifi and Ethernet all work fine ..
                  On My K-R42 Old version my wifi and Ethernet work Fine ...
                  I do NOT use XBMC .. But I do hook up through My Network Wired Ethernet ...
                  and Stream My Videos with Stock Media Player with out issue ...
                  Sometime I use MX player But Mostly the Stock Video Player as I only use mp4 and mkv which work fine with the Stock Video Player ...
                  My Bug Report is listed above ... as are the Things I did to Mount the SDCARD
                  and Format the NAND Flash ...
                  Michael T.
                    Originally posted by michael2t View Post
                    Hello D1dd1,
                    Good Luck
                    Michael T.
                    Thanks, I can mount it now.
                    But I still have the permanent shutdowns (I call it light blue screen of death )
                    @wasser: Do you have any idea what this could be?
                    If you need any system log or information just let me know.
                    Thanks guys
                      T-R42 or K-R42?
                      Hello WapVirus,
                      Michael T.
                      So I am new to Android, past years and still all my devices running ios, iPhone 5 and jbatv2. About to make a switch to see what android has to offer, especially looking at Android TV. So with great interest I am reading this thread to inform me and prepare for purchase. I am heading towards the T-R42 or K-R42, also the ouya for a while. I will using it for XBMC and some apps from Google Play Store. XBMC I only use for streaming from add-ons, what I have been doing with my atv2 past years. So I won't use it for playing any files from my nas or network. What I have understand there are very good custom roms firmware for both the T-R42 and K-R42. Only thing I was worried about is the thing with the different versions of the K-R42, dont want to open up the device. Since you have both the devices what would you recommend me to buy, which one runs more stable/smoother in your opinion? Which one would be easier to customise with newe firmware? Glad to hear from you.
                        Hello Lestercity
                        Hello Lestercity,
                        I have both devices and both are works in progress ... The K-R42 was first but has two different
                        Versions ... The T-R42 came next and Has Working Blue tooth the K-R42 does NOT ...
                        The Truth is both are currently works in progress ... and Once Wasser gets few more bugs worked out They should both be great players ...
                        Michael T.
                          1.2.3 firmware is coming
                          Changes in 1.2.3:
                          - fixed wifi regression
                          - fixed bluetooth regression (t-r42 model)
                          - preinstall xbmc
                          - passthrough support in xbmc
                          - fixed lan rx network traffic
                          - fixed issue by formating the NAND Flash
                          - support static ethernet mac adress
                            Hi T-R42 owners.
                            For T-R42 issues, please use this new thread:
                            http://www.freaktab.com/showthread.p...ware-by-wasser
                            Thanks for your numerous reports !
                              sorry! edit
                                Revision?
                                deleted
