T-R42 custom firmware by wasser
Originally posted by Herzie View PostTried downloading 1.2 three times, but I get download failed right at the end every time. Anyone else get this?
I used Google Chrome and somehow it flagged the file as harmful but I went to the downloaded folder and clicked on the Keep button to finish the download.
Not sure if you got the same thing.
Originally posted by wasser View Post
wasser -SDCARD Broken
Hello Wasser,
First, Thanks for the NEW Firmware...
But I am sorry to report there is a problem...
Here is what Happens I load Your NEW Firmware as Directed and
When I go To wipe/data I get the Following :
Formatting /data ok
/cache ok
/sd_ext ok
Error Mounting /sdcard/.android_secure!
Then It will not mount the SDCARD no matter what I do
The rest of the system seems to work ...
But this causes me lots of Error ...
Can Others please Test ...
CWM Wipe/format errors and SDcard will not mount ...
With Latest System.img
Please help ???
Michael T.3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
CVSB-K200-Wireless Mini QWERTY Keyboard / Motion Mouse for Android RF
Rii Mini i25 Qwerty Keyboard/Motion Mouse For Android RF
Media Flow Suite ... 24 TB ReadyNas Pro wired 1 GB Ethernet
Formatting /data ok
/cache ok
/sd_ext ok
Please help ???
Michael T.
My box is fine with Nand Flash and External SD Card with the new firmware. Both mounted correctly and worked fine.
If your Nand Flash not mounted then do these steps:
1) Go to /Settings/Storage/Nand Flash
2) Do mount Nand Flash if it not currently mounted.
3) If you get "Blank Internal Flash" message down in the status bar then click on it from the status bar. You will get a message that it needs to be formatted before use then just go ahead and format it. It should work fine after formatted.
Xatang2013
Hello xatang2013,
Thanks -
Here are the Complete steps for all :
3) If you get "Blank Internal Flash" message down in the status bar then click on it from the status bar. You will get a message that it needs to be formatted before use then just go ahead and format it.(NOTE:FORMAT MESSAGE HIDES you MUST Select Message on staus bar to See Format request...or at least I did )
4) Reboot to CWM
5) Select Wipe/Format all data and cache
6) Mount Sdcard ...
I could not get SDCARD to mount until going into CWM and Wipe/Format then Mount SDCARD under CWM ...
Then it will work ... Lots to do with this update....
Originally posted by michael2t View PostHello xatang2013,
Thanks -
4) Reboot to CWM
6) Mount Sdcard ...
Michael T.
Does your device boots faster and runs hotter with the new firmware compare to the previous firmware? My device AnTuTu gave a scoring of 18560 and touching the box feel a little hot.
I also had a Minix Neo 7 box and over clocked it and the best AnTuTu gave is a scoring of 17000+ but it runs a lot cooler or the case is cool when touching it.
Thanks.
Xatang2013
Hello xatang2013,
Currently ... No ...
I am going to try to see if my Sleep Bug is still there ...
I go to Setting and Debug and check stay awake ... if power is present ...
And IT was Shutting off over night and it should not .. .
Also Do You have a issue with the Power Button .. My Power Button
Use to Go to Sleep with One press now I have to Hold it and select Sleep
otherwise it turns off and I have to Get up and Use the switch on top to restart the unit ... ??
My usb remote power button goes to sleep ok, but my ir remote turns off the unit and I have to get up and use the power button on the box to turn it back on ...
Do You ??
You can Ask Wasser if the kernel is over clock ...
I am NOT sure But I do Know that the Wassers Kernels When NOT over Clock do
Hit 18400-18600 on Antutu set at 1.6 ghz which is normal clock rate ...
Both my boxes (K-r42 & T-r42) run warm but not hot ...
Michael T.
Thanks.Last edited by michael2t; 29 October 2013, 13:09.3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
Do You ??
Michael T.
I never have the Sleep Bug you mentioned. If I have the "Stay Awake" checked in the Developer options then it stayed on forever and never shut down. Not with the previous firmware and not with this new firmware.
The Sleep/Awake through IR remote never worked right for me. I always have to press and hold the Power button on the remote to bring up the Sleep/Reboot/Power Off screen. With previous firmware if I do Sleep through IR remote then I can't wake it up through IR remote. I have to push the little button on the device to wake it up. Wasser is trying to fix the Sleep/Wake Up with IR remote with the new firmware but it is still buggy. It is working but not consistent. For me 1st and 2nd times Sleep/Wake Up fine through remote. It didn't do the 3rd times then I have to push the little button on the device to wake it up.
The new firmware I would say close to perfection for me if the Sleep/Wakes Up/Reoot/Power Off working through IR Remote.
please test and report, thanks!
Wasser...
Hello Wasser,
First, Thank You for all of your hard work ...
I wanted to know is there a setting in one of the .kl files so that When I press the IR remote Once it
Sleeps like my USB remote does ... And Then I could Press it Long Time to Get Menu Option ...
I noticed Very strange Behavior Last Night Testing Ir Remote ...
If I turn on power and Start Player (From Button on player)... Remote Will Turn off Player When I press Power Button ...and NOT wake up ...
But If (Press IR long Time ) and I reboot From Power Menu then the power Button Will Sleep like USB remote ... after Reboot ... Very strange ..
I hope this helps ...
I will do testing today on NEW firmware ... thanks again
Michael T.
Originally posted by wasser View Postyou cannot wake up your t-r42 from "Power off state", it's not supported from the hardware. But wake up from Standby/Sleep mode should work with IR remote. I uploaded new 1080p kernel. I hope with this kernel you can wake your t-r42 from Standby/Sleep mode with the stock IR remote.
http://d-h.st/2Ha3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
Wasser New Sleep Firmware
Hello Wasser,
It Works Great ... The First 3 to 5 times you use it ...
Then it turns off and will NOT turn back on at all even with the Power Button I have to Unplug it and
Plug it back it to get it to Turn back On ...
I will Leave Unit on Over night to Test Sleep Bug I have been Having ...
I will Report More After More Testing ...
NOTE: I have 10 Port Powered USB 2.0 Hub with USB Keyboard , USB Mouse and USB Hard Drive all Plugged in. These Power Backup up fine ... When it does power Back up ...
The First 3 to 5 times before it fails ...
PS. Wasser could You please PM me a link to The K-R42 Kernels that You said fixed this issue on your system for 1080p and 720p kernels ... Thanks
http://d-h.st/2Ha
I came from the traditional media players and might be asking too much for what the device can handle ATM.
For me either stay on forever with the Stay Awake checked or Sleep request by me through IR remote. If Sleep then I want to wake it up through IR remote. Hope the new kernel finally fixed the Sleep issue then I am all set.
Thanks.
Michael T.
There are currently 2581 users online. 1 members and 2580 guests.
