[ROM] Beelink GS-King X & GT-King Pro ALVATECH Android TV - ATV (9.0 Pie)
    Beelink GS King X Android 9.0
    Hello, can someone please send me the settings.apk system app for android 9.0?
    But not the one with the white background, but the black one with the sidebar on the right. Please, I'm going insane and can't find it. Unfortunately I uninstalled it and didn't back it up.
    1000 thanks to you.​
      Hi. I want to use all of homelauncher options.but some of them are locked .how can I unlock them.(the pay method does'nt work).
        hi, is there android tv rom for SB9X? if theres is, will you please give a link for it? thanks in advance.
          GT-KİNG Pro C922H seri numaralı kutuya hangi romu USB yazma aracıyla nasıl yükleme yapabilirim. Açıklamalı olarak anlatırsanız memnun olurum.
            I've installed it, but I'm having a huge problem with the settings!
            Whenever I go to Settings, the shows the "Settings" title, and a white background, and it just get's stuck there! and eventually freezes the TV BOX!
            Did anyone solve this issue?!
              You may try to reflash your box. I haven’t had that issue. Please try to reflash and report back.
              Thank you,
              ALVATECH
                Thank you,
                ALVATECH
                Already tried that a couple of times before, still crashing on both: Droid/TV settings.
                  Not sure why this is happening to your box unless you’re using the ROM that isn’t intended for your box. Please make sure this ROM is compatible for your device. I have used this ROM plenty of times and this is the first time I heard of someone having issues with the TV Settings.
                  Thanks,
                  ALVATECH
                    Thanks,
                    ALVATECH
                    Thanks for the reply!
                    i'm using the rom that is compatable with S922X
                    What's written on the box is: S922x-H
                    does that matter?
                      does that matter?
                      Hello,
                      you should have installed the ROM from the link I specified down below. Also, you should have posted your concerns on that thread too. But either way like I mentioned, I can’t help you since I haven’t experienced any of these issues myself. Neither have I seen anyone else bring this type of issue up. This is an older ROM and it’s been up for years and nobody that I know of has brought this to my attention either.
                      Thank you,
                      Alvatech
                      link to S922x ATV ROM:
                      [ROM] Beelink GT-King ALVATECH Android TV - ATV (9.0 Pie) S922X Please read the entire first post before asking questions. Thank you. This is a nice clean ROM with some tweaks, GUI cleanup, Mods and some changes made from the original GT-King ROM. This ROM was converted into Android TV if you're looking for a Standard Android
                        Hello,
                        Thank you,
                        Alvatech
                        Thanks again!
                        The strange thing is that on the Box, it says chipset S922x-h, and on the device itself, the serial starts with SB9H. So which one should I take? ?
                          Thanks again!
                          I understand you now. You said on the box it had S922X so I thought you were referring to serial number. So yes, this is the thread and go by the ROM that matches your serial number on the first page/thread. There’s not much else I can do to help. I don’t have plans to update this ROM anymore and already a few years old.
                          Thank you,
                          ALVATECH
                            Thank you,
                            ALVATECH
                            Okay well, thanks anyway man!??
                              Thanks for the ROM!
                              Can I change the look of the Play Store from TV navigation to normal?
