[ROM] Beelink GS-King X & GT-King Pro ALVATECH Android TV - ATV (9.0 Pie)
Originally posted by ALVATECH View Post
Hello,
not sure what you mean. But I haven't messed with any CEC features. So the way it acts in factory ROM is the same way it acts in this one.
Thank you,
Alvatech
Rom version is 907P0.Last edited by zyousuf; 03 January 2020, 22:19.
Hello,
Yes you can update the apps without any issues, worst case scenario you would just need to uninstall previous version if for some reason it doesn't update properly. But you shouldn't have to re-flash box just to get apps updated.
Thank you,
Alvatech
Originally posted by Kuzuri View PostHi Everybody
I have just bought my new GT King Pro C92X and I found out that by connecting my second external hard drive, the WiFi disconnect from modem and by removing hard drives again connect to WiFi. It driving me CRAZY. Could anyone please HELP Me. ALVATECH please help
Most likely the device then doesn't have enough power for 2 hard-drives and the wifi.
Thank you for responding
so you think there is something wrong with DC Adapter. should I change it? Can I use another DC Adapter with 5 A Outlet for solving the problem?
Hello Alvatech, firstly I would like to thank you for firmware, which I put into my new gt-king pro straight away. I would like to ask, if anyone here have issue with default remote, to be responsive only for about 2 meters, after that looks like bluetooth does not connect. How to solve it? Thank you
Originally posted by maryann View PostCan this Rom be dual booted from an SD card like you can with Coreelec ?
Thanks.
When in the GT King home screen I long pressed on the power button, selected the option to boot from the sd card & it actually updated the box to the ALVATECH Android TV firmware.
I thought it would just reboot into the ALVATECH Android TV like it had with the CoreELEC firmware previously ?
How can I set up the box so I can dual boot between the Beelink software & the ALVATECH Android TV or is that even possible ?
I loaded ALVATECH Android TV to an sd card & inserted it into the GT King Pro.
This more than replaces the beelink android, no need to go back to stock, u can dual boot android or Linux from SD
As far as i know android has to run from internal not SD
ALVATECH Just installed without any issues ... remote and VA works
Thanks !
There are currently 1992 users online. 0 members and 1992 guests.
