[ROM] Beelink GS-King X & GT-King Pro ALVATECH Android TV - ATV (9.0 Pie)
So, I haven't been on in a long time. Does this ROM already have root, and why should I be concerned with Safetynet (sorry, don't know what it is)?
I have an older ROM, that I think was, don't mean rudely, but "generic" across all Beelink GT-KING and GT-KING PROs.
At first I didn't like the ATV versions, but I'm used to it, so don't want to change.
How fluid and bug/glitch free is this ROM? I notice it has the most replies, so I assume it is the most popular?
Why is the file NOT a .img file? How is that supposed to work in USB Burn Tool, when it ask for .img file?
Thanks in advance.Last edited by Don_Pachuco; 01 May 2020, 04:41.
Originally posted by Don_Pachuco View PostSo, I haven't been on in a long time. Does this ROM already have root, and why should I be concerned with Safetynet (sorry, don't know what it is)?
Thanks in advance.
This ROM is very stable, I don't have problems.
This is a IMG file on the link on the first page.
Originally posted by Franic7 View PostHello, what differences are there between SN: 922H, C922H and SA9H
Originally posted by RiCkLaR_atvX View Post
The SN is the Serial Number Prefix, example 922H1234567890 found on the bottom of the GT-King Pro. So, you must match the SN firmware version and the devices SN number or you will Brick your device if you install the wrong firmware version.
I have looked on Aliexpress, Geekbuying and Gearbest and I am not convinced by any seller because I see that in the reviews many buyers complain that the frequency given by the A73 processor is 1.7Ghz and not 2.2Ghz as it should be .. Apart from that a vendor says that he did not send an SD card with CoreELEC that now they sent the tvbox with CoreELEC pre-installed ... and that makes me very suspicious. That is why I look here in the forum to see if I see something that clarifies a little, I do not want to spend money on a product that is not what it should be ...
Originally posted by Franic7 View PostThank you for the answer, friend, but if you knew that, what I have tried to ask is what differences each device in the different series have between themselves, if there is any improvement or something like that between the different series ... for when I go to Buy it then ask me what series they are going to sell me, or if instead they are all the same.
i have looked on Aliexpress, Geekbuying and Gearbest and I am not convinced by any seller because I see that in the reviews many buyers complain that the frequency given by the A73 processor is 1.7Ghz and not 2.2Ghz as it should be .. Apart from that a vendor says that he did not send an SD card with CoreELEC that now they sent the tvbox with CoreELEC pre-installed ... and that makes me very suspicious. That is why I look here in the forum to see if I see something that clarifies a little, I do not want to spend money on a product that is not what it should be ...
Originally posted by Franic7 View PostHello Alvatech! Congratulations on your great work! I have asked a question, but it has been detected as spam ... I just want to know if this magisk and twrp recovery tutorial is worth it to do the installation in the official factory rom
Please do not quote an entire post. This is probably why the system marked your message as spam.
Magisk is to hide root, which helps with some apps detecting root, but not all. TWRP has a lot of different functions so depending if you need those functions. You may lookup online the different functions it has to offer. If you get a new box and try a custom ROM you can always go back to factory ROM using the original ROM from Beelink's site. So unless you see a need for this then you can try them if needed. If you're using stock ROM then please start a new thread or look for existing threads with similar questions and ask questions there. My work is for my ROM's and I put details and description per. I do not make Magisk nor TWRP so please look up info on each one to determine if you would need either one.
Thank you,
AlvatechLast edited by ALVATECH; 19 May 2020, 21:23.
Originally posted by ALVATECH View Post
Hello,
You can remove by deleting the folder in root system/apps/Chrome once you delete you can install your own. Make sure you uninstall any updates too first for chrome for it to be fully uninstalled.
Thank you,
Alvatech
first of all thank fot your work @alvathech
but i have some problem and i wont to know if its a bug or only my device problem
i bay gt king pro SA9H a week ago
i opened it and installed your rom (didn't test the original rom before)
and i bay also a new 100$ gamepad
but the gamepad have alots of strength problems and it not function properly
i have 2 more gamepad and i have the same problem with them
all 3 gamepad works perfectly with the xiaomi device
what do you think is the problem?
There are currently 2963 users online. 1 members and 2962 guests.
