[ROM] Beelink GS-King X & GT-King Pro ALVATECH Android TV - ATV (9.0 Pie)
Guest
Good afternoon, how are you?
First thanks for sharing Alvatec's room for Beelink Gt King, I thought it was great, congratulations on the work.
I use Deepin 20 operating system (Linux based debian), I can do the whole process described in the link https://forum.freaktab.com/forum/tv-...s/s922x/others -s922x / firmware-roms-tools-dq / 789302-rom-beelink-gt-king-pro-alvatech-android-tv-atv-9-0-pie-s922x-h
Deepin? if yes you could indicate some programs to replace, pis these are for windows.
Click needed link down below to download tool needed.
USB Burning Tool Method: Amlogic's USB Burning Tool
SD Card Method and Instructions: Amlogic's Burn Card Maker
Thank you very much in advance,
hug
Best Regards
Jacques Torres
[email protected]
Originally posted by arico1234 View PostHello all
I need help. I have installed this Rom but I do miss the option to switch user to openelec. How can i use dual boot option with this Rom.
Please advice ?
Create your CoreELEC OS onto a SD card, using the correct DTB, and insert it into your King Pro. Power off your box, depress the "reset" button as your power your box back on. Keep the "reset" button depressed for about 15 seconds, after you applied power. You should then be booted into CoreELEC. You can swap back and forth between CoreELEC AND Android.
Also can u explain how to reset Openelec to stock version. As I have installed a kodi build which i want to delete and go back to normal openelec version.
Openelec was already installed on SD card when i recieved the box.
Thanks for the reply. When u mention reset, do u mean to use pin for the small hole on box to press?
Yes, the first time you use CoreELEC on your SD card, you have to depress the "reset" button inside the hole.
Do I have to do that everytime i have to switch from Android to Openelec?
No, you only have to do it the first time, and never again.
I am not sure what you mean? CoreELEC has an option to "reset" back to factory, it is in the CoreELEC settings.
Originally posted by arico1234 View PostThanks for the reply. When u mention reset, do u mean to use pin for the small hole on box to press? Do I have to do that everytime i have to switch from Android to Openelec?
Hello everyone,
It has been a while. I've been pretty busy with lifestyle changes and other projects. I've updated the first post with a newly made ROM. I hope you'll enjoy the new updated ROM. I don't have as much free time as I use to, so please try to help each other with any questions in my absence. I have updated the 2nd post with some updated info on how to pass SafetyNet and a few other tips. I have now released 2 different types of ROMs one being Standard Android and the other one being Android TV. Thank you everyone for all the positive vibes/feedback and also donations I really appreciate it.
Stay safe and thank you,
Alvatech
P.S.
I would like to thank clarkss12 for all his help with some beta testing.
You're very appreciated.Last edited by ALVATECH; 12 December 2020, 05:08.
Just want to add that this ROM running on the GS King X supports the native "file server" function perfectly. Also, to be noted, that this the only device that I have found that is NOT Google Certified that can play Google Movies, Vudu, Disney+, etc in HD with DD+ audio. Just fantastic.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by Tsunarun View PostHi Alvatech
First I want to thank you for the work you do....
I have a probleme with the new rom. I on the GT King pro s922h.
When i switch the box off it turns on immediatly every time.
I have to unplugg it anytime. I don't know why
Regards
Tsunarun
I have sent you a PM (Private Message), and we have now got it figured it out. I have released a ROM specifically for the GT-King Pro with SN:922H, for those of you who may have had the issue of the box not staying shut off. I appreciate you Tsunarun for testing this out for me. Please see the first post for an update on this specific box.
Thank you,
Alvatech
There are currently 2895 users online. 1 members and 2894 guests.
