[ROM] MINIXFREAK OS ""2020 Update""
Originally posted by minixfreak View Post
still working on it trying to figure out the cec wake up issue/black screen .... the ill fix in v6 and make h96 max x2 then
minixfreak : yours is the fw with best wifi range! What do you do to wifi settings? :-P
Is it necessary to port the h96x2 to HK1 PLAY 4/64GB DDR3? This unit has BGA board....not that easy to short pins...in case of a brick
Originally posted by soldiaz View Post
Then ill wait :-P
Is it necessary to port the h96x2 to HK1 PLAY 4/64GB DDR3? This unit has BGA board....not that easy to short pins...in case of a brickbig things coming
i might make one for that in the future , right now i have v6 ready for all beelinks 9.0 devices just making h96 max x2 then ill release and start working on other projects ... minix has also agreed to send me devices and make some firmware for them ...big things coming
So how do you tweak wifi? :-P
minixfreak 1 hour ago there was a h96 max x2 build in Minixfreak OS v6 dir here: https://mega.nz/#F!xoQTFY6Y!o8aglkw8-1HqQQA41IkHBQ
Now it is gone....
Originally posted by soldiaz View Postminixfreak 1 hour ago there was a h96 max x2 build in Minixfreak OS v6 dir here: https://mega.nz/#F!xoQTFY6Y!o8aglkw8-1HqQQA41IkHBQ
Now it is gone....
In remaking it to fix the issues ... I didnt fully test everything and want this build of h96 max x2 to be up to pair with my beelink builds
thanks
Update ... I added the old build I made for h96 max x2 .. use for now wont have time to properly put together a newer build for joth revisions until weekendLast edited by minixfreak; 20 February 2020, 19:35.
There are currently 1977 users online. 3 members and 1974 guests.
