[ROM] MINIXFREAK OS ""2020 Update""
Originally posted by minixfreak View Postso i made a h96 max x2 version and uploading now ... i did this blindly .... it should work but havent tested it yet .... please test and let me know ....your welcome everyone ....
Wifi: I'm not able to get past 2Mbps speedtest performance even though I have 80Mbps connection. YouTube can't even play a video at 480p without buffering. It works fine sometimes for a few seconds but gets slowed down and sometimes give pop-up that internet connectivity not available.
Google Play Store: The Play Store updated to the latest version once I opened and closed it, but the problem is I'm getting the dreaded "Download Pending" issue. The existing apps won't update and I'm not able to install any new apps as they also give the same "Download Pending" status and nothing happens. I tried the fixes mentioned by others like clearing the data and cache of Play Store and Play Services along with deleting the Play Store update and then re-updating but still the same issue.
Would appreciate your feedback on how to fix these two issues
Originally posted by markshane View Post
Hi minixfreak, I flashed this ROM on HK1 Play 4GB DDR3 version and it boots well and performs excellent. But I'm facing the below 2 issues which I hope you can guide on fixing:
wifi i can take a look .... and the playstore issue .... i dont have the device and made this firmware completely blind ..... anyone else having these issues ... and by the way this firmware is for h96 max x2 and not hk1 play... it may load but its different firmware altogether .,,, so if anyone can confirm these issues on h96 max x2 i will take a look
Thanks for your reply. I understand, hopefully someone else can join in on their experience on H96 Max X2
i use v6 in my opinion the most stable version so far for my u214 h96 max x2Last edited by senabaj; 12 March 2020, 19:41.
Originally posted by senabaj View Post
h96 max x2 wifi has no problem specified. The Google Play Store has the following problem: Download pending ...
There are currently 1938 users online. 3 members and 1935 guests.
