I am on MINIXFREAK OS V4 and thought it was great to just update through zip :-P
[ROM] MINIXFREAK OS ""2020 Update""
Originally posted by senabaj View PostH96 max x2 v6 problem black screen when playing video
need to rearrange - vendor- build.prop
find- media.omx.display_mode = 1 edited to media.omx.display_mode = 0 save restart box
please minixfreak better explain i use google translation
Originally posted by minixfreak View Post
its the mode at which the device uses for display s905x2 s905x s905x3 probably all use 0 while s922 use 1 .... i used a s922 build prop for all my builds ... thought it was all universal but will correct it in v7 when i have the time
I am interested in what wifi tweaks u used? Connectivity and data throughoutput is awesome!!
you made a lot thank you for your work ...
i'm following you work and i noticed that amvdec_avs.ko- amvdec_vp9.ko and others from H96 and not from GT1 were used ... in previous editions you used GT1 codecs and I think the video quality was much better I don't know if I tried ... I replaced them but it didn't work
Hi
Have you tested the gamepad on the h96 x2 max? On previous versions, the steering wheel in the games did not return back to the zero position, on Real Racing, etc. I.e. the car goes either to the right or left, does not go straight. The problem is in the firmware. I tested different firmware for a long time, it came from some version, I do not remember... Box version with LPDDR3
Hello,
Tried installing the H96 max x2 file, but I only got a error when burning the rom to my device.
I have the DDR3 4/32gb version of the box. Iam using POISONTV_H96MAX_X2_V3.img and this rom works. Is there any other rom I could try? There’s a bug on the one Iam using now. I get a black bar to the right on my tv, it appears and disappears.
I have the DDR3 4/32gb version of the box. Iam using POISONTV_H96MAX_X2_V3.img and this rom works. Is there any other rom I could try? There’s a bug on the one Iam using now. I get a black bar to the right on my tv, it appears and disappears.Last edited by kalikimaka; 29 February 2020, 16:59.
Originally posted by kalikimaka View Post
You can see here - https://4pda.ru/forum/index.php?show...#entry94345379 any roms for your box
Thanks for your respons! But non of the ATV roms on that page works on my unit, minixfreak roms are the only ones that works.
There are currently 2041 users online. 0 members and 2041 guests.
