[ROM] MINIXFREAK OS ""2020 Update""
Originally posted by minixfreak View Post
you can tweak the actual driver files ... but driver files are different depending on platform like rockchip has completely different way to utilize drivers then rockchip for example
I thought of just editing some text files :-p
hey minixfreak, thanks for all the hard work, you've made my little device all the better! I've got the h96 max x2 and see that the img for this is no longer in mega. Not a huge problem as I've got it flashed and everything's stable, but wanted to check if you're discontinuing support for this box or are you working on a fix for the playstore issue? I understand it's difficult now that you don't have a functional box, so if you're no longer able to support thanks again!
On the playstore issue i was going to have a tinker by flashing ATV gapps from opengapps via TWRP in the hope this might help, but wanted to check with you if you saw any problems with doing this? Without the img file i can't restore so would be happy to stick with aptoide store as this works (cant seem to get the ATV version of kids youtube though!).
Another silly question if i may, if flashing gapps is ok would i use the ARM64 package?
Originally posted by casper1977 View Posthey minixfreak, thanks for all the hard work, you've made my little device all the better! I've got the h96 max x2 and see that the img for this is no longer in mega. Not a huge problem as I've got it flashed and everything's stable, but wanted to check if you're discontinuing support for this box or are you working on a fix for the playstore issue? I understand it's difficult now that you don't have a functional box, so if you're no longer able to support thanks again!
no idea i dont have that device
Though I do load them from an external USB enclosure which is USB 3.
I don't want to take out a mortgage in the process though, if you know what I mean.
minixfreak I have backed up v 6,7 and 8 for H96
Can I repack with V9 recovery (TWRP) ?
Maybe someone else could advise which is most stable on H96 unit, I am still on V4 and it works good
Thanks for answer
Originally posted by soldiaz View Postminixfreak I have backed up v 6,7 and 8 for H96
Thanks for answer
Originally posted by minixfreak View PostMinixfreak OS V9
Changelog
-Based On Official Beelink Firmware
-Dual Boot To Coreelec
-Used AndroidTV SystemUI Instead of Stock
-AndroidTV Remote Control ( Voice Typing Works)
-Voice Search
-Added Numerous Remotes
-Added Advanced TVSettings ( More Control Over Settings )
-Rooted With SuperSU
-Autoframerate App Added
-Customized Theme and look
-Customized Appdrawer
-Updated Wifi Drivers (Increased Buffers)
-New Build.prop Tweaks
-Updated Busybox
-My Minixfreak Tweaks
-Added Recents "Grid format" DoubleTap Home
-Extremely Fast
-Fixed SystemUI Bug ( Hopefully )
BUGS
-You Tell Me
Downloads
ScreenShots
Coming Soon
Thanks and regards
There are currently 1927 users online. 3 members and 1924 guests.
