[ROM] MINIXFREAK OS ""2020 Update""
Tested on T95Q working perfect.
(GT1_MINI_95X2)
How I can change the App Drawer background please??
Originally posted by minixfreak View PostYour not it's part of my firmware
Originally posted by matt151515 View PostTested on T95Q working perfect.
(GT1_MINI_95X2)
I have the newest T95Q 32GB(Came with Android 9 TQ_0005 Build) I tried the GT1_MINI_95X2 and it stuck on the minixfreak os logo on boot for 20 mins reinstalled original os back and it booted up within 5 mins. Is this newer version T95Q not going to work? Was hoping to try your os!
minixfreak really like your rls a lot, I am using it on HK1 play 4GB DDR3 and I wonder, wether I can use ALVATECH Magisk patched recovery for your releases instead of SU?
Originally posted by soldiaz View Postminixfreak really like your rls a lot, I am using it on HK1 play 4GB DDR3 and I wonder, wether I can use ALVATECH Magisk patched recovery for your releases instead of SU?
su in v4 does not work saying su binary occupied.
in Case I have root access through MAGISk I could remove...
minixfreak did you do any modifications to any other partitions than SYSTEM and VENDOR? So if you only modified SYSTEM and/or VENDOR I could unpack my V4 port and rebuild with V7 SYSTEM and V7 VENDOR
Originally posted by soldiaz View Postminixfreak did you do any modifications to any other partitions than SYSTEM and VENDOR? So if you only modified SYSTEM and/or VENDOR I could unpack my V4 port and rebuild with V7 SYSTEM and V7 VENDOR
There are currently 1920 users online. 3 members and 1917 guests.
