It works for me
NEW - Prometheus Finless ROM 1.3
Originally posted by convict View PostIf you have a normal keyboard, wireless or not, just press ctrl+alt+delete.
It works for me
Does this player come with an IR receiver? If not, is there a way to attach an IR receiver on it and control the player with a IR remote? If so, would it be possible to use a power on button on the IR remote control to power up the player?
CheersTronsmart "Prometheus" VS-ATV-106
Dualcore 8726-M6 @ 1.5GHz - 1GB RAM 8GB iSD
Finless ROM 1.3 - Android 4.2.2
XBMC v13 RC1
Only reboot works on the reboot apps that I have tried. I guess that is why this box has a physical shutdown switch. I learned that some android boxes and sticks can do soft shutdown.
Originally posted by seko92 View PostIt's not working, the devices freezes.
Bob,
Is it possible to add a shutdown button on the bottom bar like you did for MK808 ?
Awesome...Thanks! This is my first foray into android based media players. This ROM was easy to flash and install onto my Prometheus.
One thing I noticed though, is that there is a gap between the SD card port and the Prometheus body. My first attempt to put the card in was a total failure; it fell right into the body of the prometheus, which I had to disassemble to get the card out. After that everything worked great!
A few things from testing...not sure if this is a hardware issue or what. Maybe someone has experience with this:
1) Mouse seems to go out of alignment. I have just a USB corded mouse, and after a bit of use the arrow tip is no longer the 'point' of the mouse. Sometimes it moves to the lower left quadrant of the mouse pointer.
2) Is there a way to change what is on the main screen? I'm trying to build something for my parents which will only give 2 options: Netflix and XBMC.
Thanks again for this great ROM...much, much better than the bloated version that came stock installed!
Chips
Originally posted by Chips View PostAwesome...Thanks! This is my first foray into android based media players. This ROM was easy to flash and install onto my Prometheus.
Chips
Hi,have been following this thread with interest.
I have one of these units,4GB, on order & I intend to put this rom on it once it arrives.
A question to those who are using it. I have read that there were issues with the unit overheating. Does this still happen or do the units now have a heatsink fitted to keep them cool.
Originally posted by jgbyr View PostA question to those who are using it. I have read that there were issues with the unit overheating. Does this still happen or do the units now have a heatsink fitted to keep them cool.
Will this update method work with this rom? ive been thinking bout buying the 8gb model? I don't really want to use the reset button method if I don't have to cause all directions ive seen for that one seem poorly translated to english
1) Unpack a zip to SD card, Plug it in to your device
2) Go to all apps -> upgrade
3) Click on local upgrade
4) Click on go2ref-ota-%DATE%.zip
5) Click Reboot and install
6) Wait until firmware upgrades - DO NOT POWER OFF
7) After the reboot go to all apps -> upgrade again
8) Click on local upgrade
9) Select second zip (*patch.zip)
10) Click reboot and install
12) Wait until patching finishes
Originally posted by krash View PostSorry for my english, french guy here :
I just created an account to thank you Finless, your rom is perfect, it patch some issues that had me almost regret my prometheus.
But with 1080 video running great and no more bottom bar, this is PERFECT !!
So huge huge thank my friends !!
Consider a donation
There are currently 4020 users online. 0 members and 4020 guests.
