NEW - Prometheus Finless ROM 1.3
    Still regarding the random MAC on each boot I have done some searching and found this:
    Since J1nx's forum/blog has had so many issues lately I'll post here the text in his message:
    There are indeed a couple of versions out there that do not have the MAC address defined within their uBoot configuration (Bluetimes M3 as well). If uboot does not pass on the hardware’s MAC address, linux will generate a random one. This is the reason why some hardware have a new MAC at every boot.I will look into adding a script that saves the random MAC to file and uses it. The logic will then become like;
    - Uses the MAC from uboot, if not passed
    - Use the one from the config file, if not there (yet)
    - Create a random one and save it to the config file for the next boot’s
    Also found this:
    Finless Bob, do you think this could help?
    Thanks in advance
    Cheers
    Tronsmart "Prometheus" VS-ATV-106
    Dualcore 8726-M6 @ 1.5GHz - 1GB RAM 8GB iSD
    Finless ROM 1.3 - Android 4.2.2
    XBMC v13 RC1
      does anyone what the build date this ROM is for? as when i try to use it,all i get is the green guy lying on his back(with the triangle)the build date on my Prometheus is 28/5/13. which is 4.2.2 (the one with the Bluetooth not working)or better still,anyone know any ROM`s that will work with this device? thanks.(i did re download the ROM to see if that helped,but no joy)
        Originally posted by john3voltas View Post
        Anyone one else experiencing a new "random" MAC address everytime the TV Box boots up?
        I don't know if Bob still checks this topic but if he does, Bob, I was trying to run "setvenv ethaddr 00:11:22:33:44:55" on the bash of my prometheus but it says that setenv is not recognized.
        Can you help me with this, please?
        Cheers
        Have you tried setting the ubootenv.var.macaddr in the build.prop file?
          No, not really.
          Can you please describe in detail how I can do that?
          Thanks in advance
          Cheers
          XBMC v13 RC1
            No, not really.
            Thanks in advance
            Cheers
            Simply add "ubootenv.var.macaddr=AA:BB:CC:AA:BB:CC" to a new line in /system/build.prop, using rootexplorer or terminal.
              I'll try that tonight.
              XBMC v13 RC1
                Reporting bugs
                I report some bugs of this release:
                1. If you set a custom resolution it won't be remembered the next time you restart, the system resets it to "automatically choose the best for TV".
                2. The aplication to resize the output doesn't work. It crashes everytime a change is made.
                Still I'm gonna use Finless rom because, even if the stock ROM lacks those described bugs, it has other annoying bugs. Hope Finless fixes these bugs.
                  Did anybody used this SW with old TV with the AVI cable, I had problem when I used the manufacture SW, the screen was off and the when I opened an app the screen went upside down, and what would be the best setting to fit the screen.
                    OK, I was able to flash it with no issues, however, I have 2 problems:
                    1. The screen re-size doesn`t work, when I press any arrow it takes me to the home page.
                    2. I added Arabic Language to the keyboard, but it gives me Chinese instead.
                    Any help will be appreciated,
                      Today, I find out the new firmware for this device, so my Tronsmart Prometheus REBORN! Very happy with this thing, I will share to all people who have this device and boring as me before.
                      At first, I need thanks to Stane1983 and Oman, thank you saving my old device!
                      - Stane1983 Prometheus ROM 2014-03-17: http://www.stane1983.com/?wpdmact=process&did=NS5ob3RsaW5r
                      Features:
                      • Kernel 3.0.101
                      • Android 4.2.2, based on latest Amlogic sources (2013-12-25)
                      • Windows 8 UI, makes navigating easier
                      • Wifi works on older and new devices (Visson changed wifi module)
                      • Rooted (CyanogenMod implementation, Superuser accessible trough settings)
                      • Maybe more…
                      - Amazing best XBMC for AML device - OMAN XBMC 13.2: http://www.mediafire.com/download/h9sp9vzvww321bv
                      Please let me thanks to Stane1983 and Oman again, I'm so happy!
                        Hi Bob. can i flash my vega s89 with this rom???
                          no...
                          RK3288 Devices
                          - Overview BOX (LINK !)
                            Originally posted by no_spam_for_me View Post
                            no...
                            thanks for answer,and sorry for stoopid question
                              Features:
                              • Kernel 3.0.101
                              • Maybe more…
                              try this ROM today un my prometheus but ethernet connection don't run...only wfi sucks...
                              back to stock rom row...
                                Features:
                                • Kernel 3.0.101
                                • Maybe more…
                                ethernet connection don't run..+1
                                This problem can be solved?
