My website:
Even if you are not a big fan of XBMC.
If you dont want it you can easly uninstal it and
treat it as usual firmware.
Try it and you want regreat it
-ota updates!!! (can be accesed settings->about device->justXBMC update)
(also notification will apear in status bar if there is any update avilible)
-smaler mouse pointer
-new bootanimation
-bootanimation chouser under settings->bootanimation (couple bootanimations preloaded)
-new modified CWM
-new bacground LWP
-animation speed tweaks
-gpu and ram tweaks
(games like "asphalt 8" should work without any issues with gamepad and without)
-new power menu
-new launcher icon
-resolution switch updated and relocated to settings->screen
(for compatybility with some tv res is downscaled to 720, can be changed in settings->screen->resolution switch)
-reboot recovery updated and relocated to settings->tools
-reboot bootloader updated and relocated to settings->tools
-revrited settings->about device (now show justXBMC ver and real resolution of the kernel)
-conect to pc relocated to settings->tools
-new settings under settings->tools test camera (working only when webcam is conected to usb)
-fixed more bad strings
-new build.prop tweaks to speed up things
-changed default loading animation to the googletv one
-updated graphic for preloader (first boot initialiser)
-few xbmc updates
-spoofed xbmc skin to ver 9.9.9
-many other things i dont remember;p
v1.3.0
-rooted
-better mappings for xbox wirless gamepad (supports more games)
-init.d support
-gameloft fix
-nfs support with automount on startap scripts (check /system/etc/init.d folder)
also now you can youse mx player with network shares from xbmc by pressing menu button
and play with on video file
-choice of XBMC as launcher or customizable android launcher
-only needed apps left
-android settings and apps can be accesed by going to Android section in XBMC
-latest Beyond XBMC (All Thanks to Flumpster) with HW moded by lewy20041:
- lighter Confluance skin
- added "Android" section
- added "NFS, SMB, USBStorage" sections unded Video>Files
- advancedsettings.xml build into apk
- playercorefactory.xml build into apk
- changed icons and splash screen
- deleted touched skin
Screens:
(All Donations even small are really appreciated)
Download:
-Firmware-
v1.3.5
Mediafire
-XBMC APK-
(This apk is based on flumpster Beyond)
Default
(Store settings in /sdcard/Android/data)
Soon...
Launcher
(Store settings in /data/data)
Download
-OC Kernels-
(Only for advanced users)
Soon...
