hello I am a user of "minix x7" this ROM is fabulous I have not had time to test "XBMC" in regard to his "ac3" but I have some questions: I do not have access to my contacts ... I can not put the "master cleaner widget" he said parameter is stop ... Is that I can change skin for "XBMC" if so which ones??
justXBMC "new firmware for x7"
some few question
Yes i know about this. Yesterday i trayed to compile it but i get some problems. When i solve it there will be new justXBMC.apkEverything is possible if we work together!
Quick question Lewy. Is your firmware a modified version of the Minix firmware, or is it a modified version of the Ouya? I didn't think the Ouya firmware would work because of the differences in hardware. I didn't see any info in your OP.
I want to install your firmware so I can finally get XBMC working properly, but with Minix recently releasing v007 of their firmware, I don't want to deal with reloading it again if you plan to release an updated version soon. Please let me know.
Thanks,
WG
its based on minix firmware.
next ver will folow after i update the justXBMC.apk to v3Everything is possible if we work together!
Hi there, I just got my X7 today and installed your firmware on it, usability and smoothness are fantastic, thanks so much.
I was testing it out today and experienced the stuttering in video after about 94 minutes of a single video, stopping and then restarting the video "cured" the issue but I hope the XBMC update fixes it.
I had one other issue that no-one else seems to have had, when the X7 was connected to my TV in 1920x1080@60Hz or 1920x1080@50Hz, I was getting artifacting on the screen and the picture was flickering/glitching at varying frequency, much like an out of tune analogue TV. Sometimes it would be 10 seconds between artifacts or glitches, sometimes there'd be two or three a second.
Changing the display mode to 1920x1080@24Hz made it go away completely though. While 24Hz is fine for most films, I do have some stuff that's 30FPS but it also makes the menus a little jittery. Do you have any idea what the issue might be?
Thanks again!
Hi there,
I found a recent testchart for xbmc on Android on a spanish site.
Tutoriales para aprender a usar Kodi y artículos genéricos sobre aplicaciones, gadgets y el sistema operativo Android TV y Google TV .
This might be usefull for users. If i posted it on the wrong thread, sorry for that in advance.
Re: justXBMC "new firmware for x7"
Enviado desde mi GT-I9505 usando Tapatalk 2
I'm having trouble installing this firmware on my new neo x7, after the flash the boot stays with a black screen for ages (I gave up after 30 minutes).
I've tried to:
- Flash it again
- Leave it plugged after the flash with the hdmi connected to a pc monitor
- Unplugged after the flash and plugged to the TV screen
- Rebooted several times (sometime I got for 1 sec a broken Minix logo)
I used the button "Restore" from the flash tool and the last firmware. Any idea on how to fix this problem?
PS: I've installed the hybrid firmware and it works great. Only this one doesn't work for me.
Originally posted by giggitnf View PostI'm having trouble installing this firmware on my new neo x7, after the flash the boot stays with a black screen for ages (I gave up after 30 minutes).
I've tried to:
- Flash it again
Download justXBMC firmware again in case its corrupt
Download one of finless ROM's and run the flash tool 'Erase NAND (IDB)' let it count up to 4096
Then try loading Lewy ROM again from scratch
The flash tool Lewy added might have the Erase feature but I am not sure how to use it other than click 'Restore' as the instructions state.
I could be wrong. Trial and error in my case.
There are currently 2028 users online. 1 members and 2027 guests.
