justXBMC "new firmware for x7"
    Originally posted by hajvaniboy View Post
    Hello,
    which OC kernel would be safe with still improved performance?
    Thx
    In myn opinion the kernel with 1.8Ghz CPU, 600Mhz GPU and 800Mhz DDR3 MEM.
    these settings are actually the max of the chips design, not even overclocked.
    well OK the GPU basic is 533Mhz. Soo that means a little overclock on the GPU side.
    but beware of cheap imitations... Some soo called minix neo X7 boxes are not original.
    they work with cheaper chips and lousy DDR2 400Mhz MEM.
    You wouldn't believe but because of the good name of minix even in china they duplicate minix.
      Originally posted by Killerdude View Post
      NOTTRUE (Keep in mind that If You use 720p kernel you also need to flash number 5 (boot) too with a 720P boot.) NOTTRUE
      If it's bad advice -it will probably corrupt your system- you better remove it entirely from your post.. Otherwise some people may do it wrong anyway.
        Completely removed now.
          Hi, can anyone please link me to a download for lewy's 1.2.1 rom, i cant find that one anywhere in the threads. thanks.
          MINIX Neo X7
          Nitro Quickshot ROM, MinixXBMC v2, Finless- Kernel 720p-1704/798/720 <AnTuTu=20814
            There is a new version:
            MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.
            NVidia Shield TV 2015 16 GB || Stock
            NVidia Shield TV 2017 16 GB || Stock
            Buy me a beer?
              Originally posted by Molle View Post
              thanks Molle i was just about to post it
              Everything is possible if we work together!
              ApkFreak
                Thanks for the link Molle, BTW, as you mentioned earlier, did you happen to find out yet if you could do the rom & o/c kernel upgrade without losing all apk and user-data? If so, how did you achieve it?
                Thanks.
                MINIX Neo X7
                  Don't mention it.
                  BTW: This new version includes YouTube for TVs v1.7.3. Do you have a download link for that? I can't find it with Google (except from Play store).
                  Buy me a beer?
                    its hard to get;p
                    i spoofed my device to lg smart tv to get it;p
                    you can download it from my website http://apkfreak.com
                    just go to news, download link is there.
                    Link6381 please post some feedback after you done with testing ok.
                    its important, so i can fix if somethimg isnt right
                    ApkFreak
                      its hard to get;p
                      It truly is hard to find. v1.7.2 was easy in comparison.
                      I tried the 'Market Helper' app but couldn't get it to spoof a compatible device.
                      Buy me a beer?
                        Originally posted by kblgy View Post
                        hi, sorry to change the subject,,, just wondering if the ouya plugin is active on this yet? and if so how do i get it?
                        thank you, kblgy
                        easy to answer?
                          easy to answer?
                          I don't know the ins and out of the ouya plugin.
                          Lewy could answer this this question, soo be patience...
                            sory but no.
                            i will update first post soon.
                            ApkFreak
                              Lewy, can you make option in settings where you can change the icon of the mouse?
                              Also for F.Y.I I installed your new 1.2.2 and everything looks very good.
                              the animation in the start is a really nice option.
                              i also used finless kernel just like the last time. if everything works fine I will let you know.
                                Lewy, it works very nice. very nice rom, the YouTube TV is also much better then the normal one from minix. On XBMC I am now installing my Addons I let you know how it works.
