Thanks for your help.
But it's doesn't work too
I am using Minix_X7_justXBMC_by_lewy20041_v1.2.0
Any ideas?
Also I want ask you: how can I rename mounted folders names?
For example, I need folder name "Movies", not "Samba_2".
busybox mount -o remount,rw -t auto /system; [COLOR=#333333]mkdir /mnt/Samba_3 [/COLOR] busybox mount -o remount,ro -t auto /system;[COLOR=#333333] [/COLOR] busybox mount -t cifs //192.168.1.102/your_share /mnt/Samba_3 -o user=yourusername,pass=yourpassword[COLOR=#333333] [/COLOR]
[TABLE="width: 100%"] [TR] [TD="width: 150"][B]General[/B] [/TD] [/TR] [TR] [TD][I]UniqueID/String :[/I][/TD] [TD="colspan: 3"]242818020145555393475480885261207501159 (0xB6AD0CB2D0E1ECAF801DF9BFB12A7967)[/TD] [/TR] [TR] [TD][I]Nombre completo :[/I][/TD] [TD="colspan: 3"]C:\Users\Public\Videos\ExampleLATINO.ENG.x264.AC3.DTS.mkv[/TD] [/TR] [TR] [TD][I]Formato :[/I][/TD] [TD="colspan: 3"]Matroska[/TD] [/TR] [TR] [TD][I]Formato de la versión :[/I][/TD] [TD="colspan: 3"]Version 4 / Version 2[/TD] [/TR] [TR] [TD][I]Tamaño del archivo :[/I][/TD] [TD="colspan: 3"]4,47GIB[/TD] [/TR] [TR] [TD][I]Duración :[/I][/TD] [TD="colspan: 3"]2h 10min.[/TD] [/TR] [TR] [TD][I]Modo de tasa de bits :[/I][/TD] [TD="colspan: 3"]Variable[/TD] [/TR] [TR] [TD][I]Tasa de bits total :[/I][/TD] [TD="colspan: 3"]4 904Kbps[/TD] [/TR] [TR] [TD][I]Película :[/I][/TD] [TD="colspan: 3"]Example.LATiNO.ENG.x264.AC3.DTS[/TD] [/TR] [TR] [TD][I]Fecha de codificación :[/I][/TD] [TD="colspan: 3"]UTC 2013-08-24 13:01:41[/TD] [/TR] [TR] [TD][I]Aplicación de codifición :[/I][/TD] [TD="colspan: 3"]mkvmerge v6.2.0 ('Promised Land') built on Apr 28 2013 12:22:01[/TD] [/TR] [TR] [TD][I]Librería de codificación :[/I][/TD] [TD="colspan: 3"]libebml v1.3.0 + libmatroska v1.4.0[/TD] [/TR] [/TABLE] [TABLE="width: 100%"] [TR] [TD="width: 150"][B]Video[/B] [/TD] [/TR] [TR] [TD][I]ID :[/I][/TD] [TD="colspan: 3"]1[/TD] [/TR] [TR] [TD][I]Formato :[/I][/TD] [TD="colspan: 3"]AVC[/TD] [/TR] [TR] [TD][I]Formato/Info :[/I][/TD] [TD="colspan: 3"]Advanced Video Codec[/TD] [/TR] [TR] [TD][I]Formato del perfil :[/I][/TD] [TD="colspan: 3"]High [email protected][/TD] [/TR] [TR] [TD][I]Ajustes del formato, CABAC :[/I][/TD] [TD="colspan: 3"]Si[/TD] [/TR] [TR] [TD][I]Ajustes del formato, RefFrames :[/I][/TD] [TD="colspan: 3"]3marcos[/TD] [/TR] [TR] [TD][I]Format_Settings_GOP :[/I][/TD] [TD="colspan: 3"]M=4, N=23[/TD] [/TR] [TR] [TD][I]ID Códec :[/I][/TD] [TD="colspan: 3"]V_MPEG4/ISO/AVC[/TD] [/TR] [TR] [TD][I]Duración :[/I][/TD] [TD="colspan: 3"]2h 10min.[/TD] [/TR] [TR] [TD][I]Tipo de tasa de bits :[/I][/TD] [TD="colspan: 3"]Variable[/TD] [/TR] [TR] [TD][I]Tasa de bits :[/I][/TD] [TD="colspan: 3"]2 658Kbps[/TD] [/TR] [TR] [TD][I]Tasa de bits máxima :[/I][/TD] [TD="colspan: 3"]14,0Mbps[/TD] [/TR] [TR] [TD][I]Ancho :[/I][/TD] [TD="colspan: 3"]1 280pixeles[/TD] [/TR] [TR] [TD][I]Alto :[/I][/TD] [TD="colspan: 3"]528pixeles[/TD] [/TR] [TR] [TD][I]Relación de aspecto :[/I][/TD] [TD="colspan: 3"]2,40:1[/TD] [/TR] [TR] [TD][I]Modo de velocidad de cuadro :[/I][/TD] [TD="colspan: 3"]Constante[/TD] [/TR] [TR] [TD][I]Velocidad de cuadro :[/I][/TD] [TD="colspan: 3"]23,976fps[/TD] [/TR] [TR] [TD][I]ColorSpace :[/I][/TD] [TD="colspan: 3"]YUV[/TD] [/TR] [TR] [TD][I]ChromaSubsampling :[/I][/TD] [TD="colspan: 3"]4:2:0[/TD] [/TR] [TR] [TD][I]BitDepth/String :[/I][/TD] [TD="colspan: 3"]10bits[/TD] [/TR] [TR] [TD][I]Tipo de exploración :[/I][/TD] [TD="colspan: 3"]Progresivo[/TD] [/TR] [TR] [TD][I]Bits/(Pixel*cuadro) :[/I][/TD] [TD="colspan: 3"]0.164[/TD] [/TR] [TR] [TD][I]Tamaño de pista :[/I][/TD] [TD="colspan: 3"]2,42GIB (54%)[/TD] [/TR] [TR] [TD][I]Librería de codificación :[/I][/TD] [TD="colspan: 3"]x264 core 132 r2309 3b1f1f7[/TD] [/TR] [TR] [TD][I]Opciones de codificación :[/I][/TD] [TD="colspan: 3"]cabac=1 / ref=4 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=12 / lookahead_threads=1 / sliced_threads=0 / slices=4 / slices_max=4 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=0 / keyint=23 / keyint_min=1 / scenecut=40 / intra_refresh=0 / rc_lookahead=24 / rc=crf / mbtree=1 / crf=17.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / vbv_maxrate=14000 / vbv_bufsize=14500 / crf_max=0.0 / nal_hrd=vbr / ip_ratio=1.40 / aq=1:1.00[/TD] [/TR] [TR] [TD][I]Idioma :[/I][/TD] [TD="colspan: 3"]Inglés[/TD] [/TR] [TR] [TD][I]Default :[/I][/TD] [TD="colspan: 3"]Si[/TD] [/TR] [TR] [TD][I]Forced :[/I][/TD] [TD="colspan: 3"]Si[/TD] [/TR] [/TABLE] [TABLE="width: 100%"] [TR] [TD="width: 150"][B]Audio #1[/B] [/TD] [/TR] [TR] [TD][I]ID :[/I][/TD] [TD="colspan: 3"]2[/TD] [/TR] [TR] [TD][I]Formato :[/I][/TD] [TD="colspan: 3"]AC-3[/TD] [/TR] [TR] [TD][I]Formato/Info :[/I][/TD] [TD="colspan: 3"]Audio Coding 3[/TD] [/TR] [TR] [TD][I]Format_Settings_ModeExtension :[/I][/TD] [TD="colspan: 3"]CM (complete main)[/TD] [/TR] [TR] [TD][I]Ajustes del formato, Endianness :[/I][/TD] [TD="colspan: 3"]Big[/TD] [/TR] [TR] [TD][I]ID Códec :[/I][/TD] [TD="colspan: 3"]A_AC3[/TD] [/TR] [TR] [TD][I]Duración :[/I][/TD] [TD="colspan: 3"]2h 10min.[/TD] [/TR] [TR] [TD][I]Tipo de tasa de bits :[/I][/TD] [TD="colspan: 3"]Constante[/TD] [/TR] [TR] [TD][I]Tasa de bits :[/I][/TD] [TD="colspan: 3"]640Kbps[/TD] [/TR] [TR] [TD][I]Canal(es) :[/I][/TD] [TD="colspan: 3"]6canales[/TD] [/TR] [TR] [TD][I]Posiciones del canal :[/I][/TD] [TD="colspan: 3"]Front: L C R, Side: L R, LFE[/TD] [/TR] [TR] [TD][I]Velocidad de muestreo :[/I][/TD] [TD="colspan: 3"]48,0KHz[/TD] [/TR] [TR] [TD][I]BitDepth/String :[/I][/TD] [TD="colspan: 3"]16bits[/TD] [/TR] [TR] [TD][I]Tamaño de pista :[/I][/TD] [TD="colspan: 3"]598MB (13%)[/TD] [/TR] [TR] [TD][I]Idioma :[/I][/TD] [TD="colspan: 3"]Español[/TD] [/TR] [TR] [TD][I]Default :[/I][/TD] [TD="colspan: 3"]Si[/TD] [/TR] [TR] [TD][I]Forced :[/I][/TD] [TD="colspan: 3"]Si[/TD] [/TR] [/TABLE] [TABLE="width: 100%"] [TR] [TD="width: 150"][B]Audio #2[/B] [/TD] [/TR] [TR] [TD][I]ID :[/I][/TD] [TD="colspan: 3"]3[/TD] [/TR] [TR] [TD][I]Formato :[/I][/TD] [TD="colspan: 3"]DTS[/TD] [/TR] [TR] [TD][I]Formato/Info :[/I][/TD] [TD="colspan: 3"]Digital Theater Systems[/TD] [/TR] [TR] [TD][I]Format_Settings_Mode :[/I][/TD] [TD="colspan: 3"]16[/TD] [/TR] [TR] [TD][I]Ajustes del formato, Endianness :[/I][/TD] [TD="colspan: 3"]Big[/TD] [/TR] [TR] [TD][I]ID Códec :[/I][/TD] [TD="colspan: 3"]A_DTS[/TD] [/TR] [TR] [TD][I]Duración :[/I][/TD] [TD="colspan: 3"]2h 10min.[/TD] [/TR] [TR] [TD][I]Tipo de tasa de bits :[/I][/TD] [TD="colspan: 3"]Constante[/TD] [/TR] [TR] [TD][I]Tasa de bits :[/I][/TD] [TD="colspan: 3"]1 509Kbps[/TD] [/TR] [TR] [TD][I]Canal(es) :[/I][/TD] [TD="colspan: 3"]6canales[/TD] [/TR] [TR] [TD][I]Posiciones del canal :[/I][/TD] [TD="colspan: 3"]Front: L C R, Side: L R, LFE[/TD] [/TR] [TR] [TD][I]Velocidad de muestreo :[/I][/TD] [TD="colspan: 3"]48,0KHz[/TD] [/TR] [TR] [TD][I]BitDepth/String :[/I][/TD] [TD="colspan: 3"]24bits[/TD] [/TR] [TR] [TD][I]Tamaño de pista :[/I][/TD] [TD="colspan: 3"]1,38GIB (31%)[/TD] [/TR] [TR] [TD][I]Idioma :[/I][/TD] [TD="colspan: 3"]Inglés[/TD] [/TR] [TR] [TD][I]Default :[/I][/TD] [TD="colspan: 3"]No[/TD] [/TR] [TR] [TD][I]Forced :[/I][/TD] [TD="colspan: 3"]No[/TD] [/TR] [/TABLE] [TABLE="width: 100%"] [TR] [TD="width: 150"][B]Texto #1[/B] [/TD] [/TR] [TR] [TD][I]ID :[/I][/TD] [TD="colspan: 3"]4[/TD] [/TR] [TR] [TD][I]Formato :[/I][/TD] [TD="colspan: 3"]UTF-8[/TD] [/TR] [TR] [TD][I]ID Códec :[/I][/TD] [TD="colspan: 3"]S_TEXT/UTF8[/TD] [/TR] [TR] [TD][I]ID Códec/Info :[/I][/TD] [TD="colspan: 3"]UTF-8 Plain Text[/TD] [/TR] [TR] [TD][I]Idioma :[/I][/TD] [TD="colspan: 3"]Inglés[/TD] [/TR] [TR] [TD][I]Default :[/I][/TD] [TD="colspan: 3"]No[/TD] [/TR] [TR] [TD][I]Forced :[/I][/TD] [TD="colspan: 3"]No[/TD] [/TR] [/TABLE] [TABLE="width: 100%"] [TR] [TD="width: 150"][B]Texto #2[/B] [/TD] [/TR] [TR] [TD][I]ID :[/I][/TD] [TD="colspan: 3"]5[/TD] [/TR] [TR] [TD][I]Formato :[/I][/TD] [TD="colspan: 3"]UTF-8[/TD] [/TR] [TR] [TD][I]ID Códec :[/I][/TD] [TD="colspan: 3"]S_TEXT/UTF8[/TD] [/TR] [TR] [TD][I]ID Códec/Info :[/I][/TD] [TD="colspan: 3"]UTF-8 Plain Text[/TD] [/TR] [TR] [TD][I]Idioma :[/I][/TD] [TD="colspan: 3"]Español[/TD] [/TR] [TR] [TD][I]Default :[/I][/TD] [TD="colspan: 3"]No[/TD] [/TR] [TR] [TD][I]Forced :[/I][/TD] [TD="colspan: 3"]No[/TD] [/TR] [/TABLE] [TABLE="width: 100%"] [TR] [TD="width: 150"][B]Texto #3[/B] [/TD] [/TR] [TR] [TD][I]ID :[/I][/TD] [TD="colspan: 3"]6[/TD] [/TR] [TR] [TD][I]Formato :[/I][/TD] [TD="colspan: 3"]UTF-8[/TD] [/TR] [TR] [TD][I]ID Códec :[/I][/TD] [TD="colspan: 3"]S_TEXT/UTF8[/TD] [/TR] [TR] [TD][I]ID Códec/Info :[/I][/TD] [TD="colspan: 3"]UTF-8 Plain Text[/TD] [/TR] [TR] [TD][I]Título :[/I][/TD] [TD="colspan: 3"]LATiNO[/TD] [/TR] [TR] [TD][I]Idioma :[/I][/TD] [TD="colspan: 3"]Español[/TD] [/TR] [TR] [TD][I]Default :[/I][/TD] [TD="colspan: 3"]Si[/TD] [/TR] [TR] [TD][I]Forced :[/I][/TD] [TD="colspan: 3"]Si [/TD] [/TR] [/TABLE]
There are currently 2141 users online. 3 members and 2138 guests.
