justXBMC "new firmware for x7"
I had a closer look. Tested some more 1080p files with real 1080p kernel. Most files played quite good, but not real perfect. After 30min box got too hot, so playback began to judder very heavy.
I restarted with 720p kernel and this is perfect.
Does anyone know how to start the OUYA mode?
My Box:
CX-921 / EXOON POWER PRODonations are welcome and will be shared with other devs:
DONATIONS
CX-921 TV-Box without Bluetooth (RK3188 / RTL8188 Wifi), CX-921b TV-Box (RK3188T / AP6210 Wifi), T428 TV Stick (RK3188 / AP6330 Wifi), CX919 TV Stick (RK3188 / AP6210 Wifi)
Re: justXBMC "new firmware for x7"
Originally posted by walter77 View PostI had a closer look. Tested some more 1080p files with real 1080p kernel. Most files played quite good, but not real perfect. After 30min box got too hot, so playback began to judder very heavy.
My Box:
Sent from my Faea HY509S using Tapatalk
Originally posted by Batfink32 View PostThe X7 has a large heatsink on the CPU so that's why your box got hot as it probably doesnt.The X7 is one of the best built boxes available.The Ouya mode is a plug in which lewy will release when he has fixed it.
Perhaps i will put a big heatsink on the cpu ;-)Donations are welcome and will be shared with other devs:
DONATIONS
Originally posted by Vishwa Somayaji View PostYou quit XBMC and it will take you to the desktop with a few icons. You can use ES file explorer and navigate to the place you have your app and install or go to Play Store app, go to store, lookup app and install from there. This rom is best of both worlds--If you are happy with XBMC you never have to leave it but it lets you have all the options from the desktop as well as soon as you quit XBMC.
Sent from my iPad using Tapatalk - now Free
but then i will have 1000 questions why xbmc start without my settings etc
it will happen for sure as sometimes xbmc will start before internall sdcard will mount
if some one know how to delay a launcher start please tell me and i will do it like you want.Everything is possible if we work together!
Originally posted by Trhuster View PostBut then i did the same with my TV-shows catalog but when scraping no cover or info shows up, and no new tab called TV-shows showed up. I can play them if i go into files but it shall look the same as movies does, right?
No video addons, help!
thanks for this custom rom. I need help baceuse no addons works with this justxbmc, only get "dependance not meet" or "script failed" on every addons I try to install from fusion; some addons try to update with Eden version, plus the superrepo is empty, so I probably miss somethings; I like this "light" rom and the xbmc installed, but It's useless for me as is, so I need help from which have the setup working fine; before I've Finless 1.6 rom and XBMC 12.2 and all work fine, what I've done wrong?
Mnay thanks,
Max
Mnay thanks,
MaxLast edited by Vishwa Somayaji; 23 October 2013, 19:32.
Originally posted by Vishwa Somayaji View PostTry reloading JustXBMC rom again and start from there. A lot of people including me have had no trouble installing Add-ons. I did one from fusion as well. It is certainly worth try as it only takes ~10-15 min. You must have spent hours already trying to install addons.
Max
yes refresh repo and you should be good.Everything is possible if we work together!
Hey Lewy.
Here is a short summery after two days of testing.
Added movie directory with smb protocol in xbmc.
Streaming with cable lan.
Day 1 with 1080p Kernel, Debugging shows about 50% cpu:
Played 1080p Movie with DTS sound absolutely perfect, but...
after about 60minutes perfect playback, movie began to sludder.
Getting heavier and heavier to the end. Every two seconds about 5 freezing frames.
Audio played perfect the whole time!
Rebooted the box and everything played great after that. Because the device was quite warm i thought it would be too hot, because of overclocked kernel.
Day 2 with 720p Kernel, about 30% cpu:
after about 60minutes movie began to sludder. Getting heavier and heavier to the end. Every two seconds about 5 freezing frames.
Just stopped the movie, played another 1080p movie - perfect.
Switched to first movie and played the last 30 minutes without any problems.
So it can't be a temperature thing.
Something with the cache seems to be the problem.
You added some network things in the advancedsettings.xml and in the build.prop.
Do you have an idea how to solve this problem?
Gesendet von meinem iPad mit Tapatalk HDDonations are welcome and will be shared with other devs:
DONATIONS
There are currently 2050 users online. 2 members and 2048 guests.
