Nextbook Premium 7 SE w/ ICS
Originally posted by solly View Postguys i've bought a microSD card for my nextbook, but when i transfer files to it through computer i cant access it from the tablet, as file manager app only seeing the internal mem as the Sdcard??!!
any solution, or other app that will be able to see the MicroSD ?
It may show up as something else but it will be in mnt folder
Sent from my SK17i using Tapatalk 2Please consider donating to purchase tablets for Finless Bob to continue his work. This will help in the creation of custom roms and build an even stronger development base for our community. Thank you for you support!
</form>
hey guys.. I'v flashing my Vandroid T2i a.k.a Nextbook Premium 7 S with Finlees Bob Custom Room.. and it works man..... Thankyou very much man... You are the man!!!but now my question's, Can I change boot animation I'm not like with animation that show NEXTBOOK text and a quote from abraham lincoln. If I can, can you tell me how to change it? Thanks before man
You need a file manager with root access. Goto system/media and delete the bootanimation.zip file if you don't like it. You can Google Android bootzips or animations and simply replace that file, but make sure it is named bootanimation.zip
Or make one yourself have a look at this guide
http://www.FreakTab.com/showthread.php?t=865
Create A Simple Boot Animation
</form>
Originally posted by Damo View PostYou need a file manager with root access. Goto system/media and delete the bootanimation.zip file if you don't like it. You can Google Android bootzips or animations and simply replace that file, but make sure it is named bootanimation.zip
My second question for finlees, when l tried to download lastest version of streamzoo and friendcaster, google play tell 'This version not compatible with this product'. But, before l use your ROM, andbuse original
om from advan Indonesia, two of that app can acces and use on this tab. Please your solution. Thanks before and sorry fo my bad english
Originally posted by anto_kp View Postplease helpme...
after flashing touch screen not funtion,my device vandroid t2i
Originally posted by aganix View Postplease check ROM for NextTablet Resistive screen not for capacitive screen. http://www.freaktab.com/forumdisplay...by-Finless-Bob( tapi saya gak seberapa paham dengan bahasa inggris)
Originally posted by aganix View PostThanks for the tutor man :-) . I've try it, but first screen always appear. Maybe there is another file that must be change too?
When it comes to the 701, there were several version with different hardware. The manufacturer had downloads for at least 4 different serial number ranges thus the Gingerbread ROMS I have to support the different YF serial numbers. But for this ICS version no one knows what the heck serial number range it supports! Only user posts that say it works on YFxxx will tell us that.
Yes this wifi issue is in fact been around a while when you flash a 701 with the wrong serial number range ROM. If you look through posts here you will see someone stating they flashed a YFxxx ROM and had no wifi. Later when they found the correct ROM to use, it fixed the wifi.
So if you have no wifi with this ICS ROM, sorry.... you do have different hardware than it was made to support.
Originally posted by Finless View PostWhen it comes to the 701, there were several version with different hardware. The manufacturer had downloads for at least 4 different serial number ranges thus the Gingerbread ROMS I have to support the different YF serial numbers. But for this ICS version no one knows what the heck serial number range it supports! Only user posts that say it works on YFxxx will tell us that.
Originally posted by aganix View Posthow about my problems bob? can't download facebook, streamzoo, and many app.. google play show a message that My device not compatible with my device, but before I flash it with your ROM, it can download that app. thx
There are currently 2522 users online. 2 members and 2520 guests.
