Thanks.
Pipo M6 Max RileyROM 1.9
Originally posted by AtulK View PostCan you please tell me what low CPU voltage kernel does, is it for a sake of saving battery life?
Thanks.
Low voltages are for better battery life (and also less heat !).
But, keep in mind that not all the hardwares are the same and some devices won't boot with a low voltages kernel. It's a matter of testing and some moments of stress !
Need Help
hi to all,
i just want to ask how to remove the label "no sim card" on the lockscreen or what is the specific file for it?
for some reason some riley rom have it and some don't and i liked it where the lockscreen doesn't have that sign. well it is not a big thing but out of curiousity if someone knew how to remove it or atleast give a hand on how to do it myself would be much appreciated.
thanks
Originally posted by Slowry View Postphjanderson's script print the freq/volt tables at startup, so here is the tables :
== Table 6 CPU ==
MHz mV
312 900
504 925
816 1000
1008 1075
1200 1200
1416 1250
1704 1375
== Table GPU ==
MHz mV
133 975
200 1025
266 1025
400 1100
600 1250
660 1250
== Table 8 DDR ==
MHz mV
800 1250 1 DDR_FREQ_NORMAL
So, no it's not low CPU voltage but stock voltage.
Here are very low voltage kernel only for "lucky hardware" like mine !
== Table 6
MHz mV
312 800
504 825
816 900
1008 950
1200 1050
1416 1125
1704 1275
[ATTACH]4154[/ATTACH]
[ATTACH]4155[/ATTACH]
For your information I also managed to reduce voltages for the GPU part by AT LEAST -75mV.
I suggest you to help me finding the lowest stable GPU voltages.if you appreciate my efforts this is the link for any donation:
Originally posted by giouncino View PostGreat! You copied all my voltages prepared for the m6pro. You are another lucky owner of a "pure" CPU.
Great work !
for the GPU, now i'm testing this one with success :
"gpu600h" =>
[800000, 133000],
[825000, 200000],
[850000, 266000],
[900000, 366000],
[1000000, 466000],
[1100000, 600000],
Which program do you use to make Gpu stress and stability test ? I use stabilty test (for scaling CPU), Antutu and some games.
it's not easy to found the voltage in use for the mali 400MP.
Originally posted by Slowry View PostHi giouncino,
Great work !
"gpu600h" =>
[800000, 133000],
[825000, 200000],
[850000, 266000],
[900000, 366000],
[1000000, 466000],
[1100000, 600000],
I'm testing a little bit higher voltages:
[875000, 133000],
[900000, 200000],
[950000, 266000],
[975000, 300000],
[1025000, 400000],
[1175000, 600000],
without any issue.
I'll check with yours soon!
The problem is not only the program to test the GPU (I also use Antutu, stability test, 3Dmark and epic citadel), but understand which is the current frequency used by the GPU.
For example do you know which is the frequency used during power on? and during normal browsing?
On 3D (like 3dmark, antutu or epic citadel I suppose it is set to 600Mhz, but on other scenarios is very difficult to understand how GPU scale the frequency...)
we need to keep in touch to share our understandings and results!
UPDATE:
GPU tested with your voltages, no problems!
Now I think that 300Mhz could work with 875mV and 400Mhz@950mV (looking for a more linear graph on excel)...
I'll test it as soon as I can!Last edited by giouncino; 01 December 2013, 11:08.if you appreciate my efforts this is the link for any donation:
up for this
thanks
Hi Randy,
Just flashed this ROM with RileyROM1.9-kernel-cpu1704_gpu660_ddr800_v.4.1 kernel. All works great but Netflix, which is the mainly used by my kids, doesn't work. When I click on a movie to play it remains on "Loading...", and never starts the movie
Please help!
Update: the same happens with the original kernel from the ROM.
Try installing Xposed Framework. There is a Netflix fix module you can run. Just Google it.
Sent from my M6pro using TapatalkRandy
I had another Pipo tablet that never came on using the power button...but did with inserting a USB. After about a week...the problem cleared up and the power button started working.
Originally posted by rrileypm View PostTry installing Xposed Framework. There is a Netflix fix module you can run. Just Google it.
Regardless, I installed the Xposed framework but it still doesn't work
Thanks, updated to 1.9 all good.
I've noticed that since upgrading from 1.8a, wifi does not start up by default at boot. Not complaining, just noting. I remember you stating that this was an issue for RR1.7 or so - interesting to note it's come back in 1.9, after dissapearing in 1.8.
The tablet is working FAR FAR better than it has for me ever. Antutu score in HD of 19,500 is huge. Far higher than I had on any stock, and general usage within the UI/Chrome/etc is just so snappy
Thanks!
edit: Oh and thanks Balrog for your altered kernels. Only V4 worked for me, but it worked a charm.
Slowry, your reduced voltages didn't work for mehehe
PiPo M6 Max 3G RileyROM 1.9
Hyundai T7s SPCleanROM 4.04
Asus Transformer Prime ChaOS 4.3.1
Samsung SGSII SlimBean 4.3 Build 2.2
There are currently 2126 users online. 1 members and 2125 guests.
