Pipo M6 Max RileyROM 1.9
    does anybody have any issues with 1.9 ROM + v4.0 kernel?
    the resulotion changes automatically to HD hence the normal is ticked, it is also very very laggy and slow, nearly unusable...
    I have just changed to HD display mode and it went back to normal mode...
    strange
      back to original
      for warranty purposes how to put back to original firmware?
        strange
        No dramas for me for that exact combo.
        It will be the exact same process as for downloading one of these RileyROMs. Randy should hopefully be able to help with a download link.
        PiPo M6 Max 3G RileyROM 1.9
        Hyundai T7s SPCleanROM 4.04
        Asus Transformer Prime ChaOS 4.3.1
        Samsung SGSII SlimBean 4.3 Build 2.2
          Here is the link to the latest official firmware form Pipo:
          You can use the RKBatchTool to flash this firmware. It is located in the RileyROM kit in the folder called "alternate_reboot_to_flash_tool"
          If you have successfully flashed one of my ROM's, your drivers will also work with the RKBatchTool.
          If your PC recognizes your tablet (pink box), click "switch"...and "restore". The stock firmware will flash.
          Randy
            This ROM appears to be for the Pro rather than the Max?
            Sent from my M6 using Tapatalk 4
              Nope... It's for the Max.
              The wifi power must have been turned down. When I get a chance, I'll check it.
              Sent from my SAMSUNG-SGH-I537 using Tapatalk
              Randy
                are you sure?
                riley are you sure?
                because the link you sent it says PiPO M6pro_software_OTA_20131204
                and in the title say: M6pro!
                  You're right... Just browse over to the M6 Max page on their site
                  Randy
                    ok thanks, riley
                    i have to send to warranty because, the touch screen started to work alone, it seems like a ghost hand, and there are zones of the touch that doesn't work smooth. i have to touch several times to work.
                      Sorry to hear that...
                      Good luck with the fix.
                      Randy
                        ok thanks, riley
                        It's not connected to the charger while this happens is it? My touchscreen behaves erratically when connected to the charger. (I believe it is noisy power output from it, as it doesn't happen when connected to the charger from my Aoson.)
                        On another note, I've just tried a few of the newer overclocked/stock kernels with my (if I remember correctly) stock rom from August, and while they boot fine, the wifi won't turn on. (Tested builds #109 and #112). #81 is the highest that seems to work properly. Also Balrogs vRR1.9_v4.1_800Mhz caused the tab to lock with corrupted screen whenever I tried to turn on USB storage mode.
                        I've gone back to Balrogs kernel_cpu1704_gpu660_ddr720_v4.img based on build #81 and all seems to working fine. One of these days I might update my ROM, but can't be bothered at the moment
                          happens when it's not connected! i didn't tried connected yet
                            Hello all !
                            Where can i find the "Pipo OTA update firmware dated 10/14/13" subject firmware based on ?
                            And can it be installed from CWM ?
                              Here's the link to that firmware:
                              百度网盘为您提供文件的网络备份、同步和分享服务。空间大、速度快、安全稳固,支持教育网加速,支持手机端。注册使用百度网盘即可享受免费存储空间
                              I'm afraid that you can't install it with CWM. It has to be installed with the RKBatchTool.
                              Randy
                                how do you install the RileyROM1.9-cwm-cpu1704_gpu660_ddr800_v.4.1
                                HI tnx for the rom 1.9, it worked great! no more hangs and crashes!!! good work!!!can you teach me how to install the RileyROM1.9-cwm-cpu1704_gpu660_ddr800_v.4.1? tnx
