Do you have a solution ? Thx
NEOMODE HYBRID ROM 1.8 MK802IV UG007B CX-919 MK809III J22 and others with AP6210
Originally posted by neomode View PostYesterday I get my new Mk802iv.
Now I can go on with it.
Neomode
Freaktab.com Developer
awesome work. Any update on this for cx-919? Also, if the device ID can be listed as samsung whatever so we get full googleplay without interference.
I tried your 1.9 for MK098 III on my CX-919, VERY slow wifi. I tried kernel1 and kernel2. I bought my cx-919 late november, that should have the new wifi chip, no? Not sure. Not very confident to open it up.
much appreciated.
Ok guys.. What's wrong with you asking for ETA???
The guy is doing this for fee on his own personal time and you're pretty much telling him to hurry??
Neomode does great ROM, the least you could do is give him time and support him.
Neomode keep the good work and take your time if it means a better ROM
Sent from my LG-D802 using Tapatalk
AW: NEOMODE HYBRID ROM 1.8 MK802IV UG007B CX-919 MK809III J22 and others with AP6210
Right now i have almost finished the Update for the old Wifi Chip. They have must wait a long Time on an Update.
Then the New Version for the AP6210 will be the next.
Neomode
Originally posted by SPM View PostOk guys.. What's wrong with you asking for ETA???
Bluetooth for MK802IV old WIFI
Dear Neomode
I was trying to make a rom based on http://www.cnx-software.com/2013/08/...-2-sdk-leaked/
All is running beside the Bluetooth. I can not turn it on ... Can you give me a hint, where to have a closer look ?
I think its the same case, when using the 802IV AP6210 rom on a 802IV old WIFI.
Thanks in advance
w4sepp
Originally posted by neomode View PostSeems that the Kernel use a different GPIO for Bluetooth. This means you need a different Kernel.
Neomode
When i use the same kernel with the the original system.img or with your 1.5 system image it works fine. >> i just change the system.img.
but i will investigate in the direction of the GPIO's
If you have another idea where there could be a difference in the system.img, I would be happy when you share it.
merry xmas
w4sepp
new with this
Hello,
Sorry, I new with android and roms, but I miss someting.
Download 720p: ( not found this one ) cx-919
Download 1080p: ( not found this one ) cx-919
Where can I found these android versions?
the j22 kernels and rk3188loader must I load these first in RKAndroidTool.exe and install it on my device?
I download on time a android version from this site, I used Rockchip_Batch_Tool_v1.7 to update, that want wrong the device did not start.
I was lucky that I found a android cx-919 15-07-2013.img and with restore it was running again.
Only a bit slower when I by the device, so I think there was a better image on it.
thanks for your help.
Regards,
Michel
Hello all,
I download the 1.8 version 1080P in this forum and upload it on my cx919 1.8ghz 2gb mem
it works,
wifi is slow, i start a youtube movie it plays but after 5 min it stopt and it reboots compleet my hdmi stick.
now is wifi a bit better.
bluetooth is not working how can I use bluetooth?
or how can I fix it again it was working on the orginal.
must I use a other image on my cx919 can someone help me that the hdmi will work ok for me with bluetooth and streaming etc what is the best for my stick right now.
I did not used :
J22 Kernels
Some People needs Loader 2.03 Download here:
RK3188Loader(L)_V2.03.zip
I download the 1.8 what was on this forum, and upload it my stick
thanks
regards,
MichelLast edited by michel30; 27 December 2013, 12:23.
There are currently 2633 users online. 0 members and 2633 guests.
